[mapserver-users] postgis - geomfromtext problem
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Oct 15 01:19:54 PDT 2012
Perhaps running legacy.sql in your new database will be enough.
http://www.postgis.org/docs/PostGIS_FAQ.html#legacy_faq
-Jukka Rahkonen-
Ahmet Temiz wrote:
> hello
> I upgraded my postgis to 2.1.0.
> But this version of postgis doesn't accept "geomfromtext" (instead
> "ST_GeomFromText" only )
> But:
> following mapserver - java related codes produce "geomfromtext" and then
> give error:
> jeoLayer1.setData("geom from (select gid,label,geom from sjeo_yas6) as
> foo using unique gid using srid=4326 "); String f = "label=" + "'" + yas + "'";
> jeoLayer1.setFilter(f);
> msDrawMap(): Image handling error. Failed to draw layer named
> '(null)'.;msPostGISLayerWhichShapes(): Query error. Error (ERROR:
> function geomfromtext(unknown, integer) does not exist LINE 1: ...'hex') as
> geom,"gid" from sjeo_yas6 where geom && GeomFromTe...
> I compiled mapserver 6.0.1
> what can I do ?
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Planlama ve Zarar Azaltma Dairesi Başkanlığı
> Eskişehir Yolu 10. km.
> Lodumlu / Ankara
> Tel : 0 312 2872680 / 1535
> ________________________
> Ahmet Temiz
> Geological Eng.
> Information Systems - GIS Group
> Disaster and Emergency Management
> of Presidency
> mapserver-users at lists.osgeo.org
