[mapserver-users] ubuntu freetype install problem
Tim Banchi
tim.banchi at gmail.com
Mon Oct 15 01:32:56 PDT 2012
Hello Vince,
on ubuntu I had to make two symlinks so the GD libraries are found:
sudo ln -s /usr/lib/i386-linux-gnu/libgd.a /usr/local/lib/libgd.a
sudo ln -s /usr/lib/i386-linux-gnu/libgd.so /usr/local/lib/libgd.so
for 64bit you have to use the following path (I think I didn't try it on a
64bit machine)
/usr/lib/x86_64-linux-gnu/
AFAIK this solved the freetype issue when compiling mapserver on my ubuntu
machine. (I still have troubles compiling the cscharp module as posted
previously on this mailing list).
2012/10/15 Vince Miller <vincentpmiller at yahoo.com>
> I need a little help installing Mapserver 6.0.3 under Ubuntu 12.04 running
> postgresql 9.1 with postgis. I had it all working with old versions of
> everything on an old server. The hangup seems to be with freetype 2.4.10.
> After some reasonable messages, the freetype ./configure step dies with:
> cd builds/unix; ./configure
> /bin/sh: 1: ./configure not found
> make: *** [setup] Error 127
> GD (version 2.0.33, which I found at
> bitbucket.org/pierrejoye/gd-libgd/downloads) actually seemed to compile
> ok even though freetype didn't. But then the Mapserver ./configure died
> because it couldn't find freetype.
> I'm not looking for anything special here (for now, at least), just a
> mapserv in a apache-accessible cgi-bin directory. It doesn't seem like I
> should have to compile it, not to mention several of its dependencies, but
> I can't find a simple "download this binary and put it here" method. The
> UbuntuGIS PPA method seems more mysterious than compile-it-myself method.
> I'm an application developer, and not a Linux wizard. Someone wanna hold
> my had a little here, please?
> Thanks,
> Vince
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121015/3038f590/attachment.html>
