[mapserver-users] 6.2.0-rc1: error while compiling the csharp mapscript module: OSGeo.MapServer.mapscriptPINVOKE.mapscriptPINVOKE()' is already defined
Tamas Szekeres
szekerest at gmail.com
Mon Oct 15 05:45:39 PDT 2012
Tim,
What is the version of SWIG you use. I'm using SWIG 1.3.39 which appears to
generate compilable code.
Best regards,
Tamas
2012/10/15 Tim Banchi <tim.banchi at gmail.com>
> Hello,
> when I try to compile the csharp mapscript module of mapserver 6.2.0.rc1 I
> get the following error:
> mapscriptPINVOKE.cs(192,10): error CS0111: A member
> `OSGeo.MapServer.mapscriptPINVOKE.mapscriptPINVOKE()' is already defined.
> Rename this member or use different parameter types.
> I tried to delete the dubble entry of the member mapscriptPINVOKE() in the
> mapscriptPINVOKE.cs file but this file seems to be autogenerated by the
> compilation process. I do understand too little of the make process to
> adapt the compile script (probably somebody can help me with that?).
> I configured, compiled and installed the mapserver with the following
> options:
> ./configure --with-wfs --with-wcs --with-sos --with-wmsclient
> --with-wfsclient --with-proj --with-gdal --with-ogr --with-geos --with-gd
> --with-tiff --with-jpeg --with-agg --with-eppl --with-postgis --with-sde
> --with-freetype --with-threads --with-experimental-png
> but also other configurations (without any parameters or disabling fastcgi
> because there is a post of 2006 with problems with the csharp module if
> fastcgi enabled) doesn't make any difference. also with older versions of
> mapserver (eg stable the latest stable version 6.0.3. or the latest stable
> version of 5.8.x) I get exactly the same error message.
> I run ubuntu 12.04 x86 and have mapserver installed via the packaging
> system (I could not not find any csharp-mapscript package),
> can anybody help me with
> - find a precompiled csharp_mapscript package for ubuntu 12.04 x86
> - adapt the compile script so the member mapscriptPINVOKE is not written
> twice
> - help me with the configuration of the mapserver to solve the compile
> problem
> Tim
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121015/40724c76/attachment.html>
