[mapserver-users] undefined reference to `__sync_sub_and_fetch_4'
David Quinn
daithiquinn at gmail.com
Wed Oct 17 09:30:22 PDT 2012
Hello List,
I'm getting the following error when I try to compile mapserver-6.2.0-rc1
$make
/bin/sh ./libtool --mode=link --tag=CXX g++ -rpath /home/david/lib
shp2img.lo libmapserver.la -o shp2img
libtool: link: g++ .libs/shp2img.o -o .libs/shp2img
./.libs/libmapserver.so -L/home/david/lib /home/david/lib/libgd.so
-L/usr/lib /home/david/lib/libproj.so /home/david/lib/libgdal.so
-L/home/david -L/usr/kerberos/lib /usr/lib/libexpat.so
/home/david/lib/libgif.so /home/david/lib/libcurl.so
/home/david/lib/libgeos_c.so /home/david/lib/libgeos.so
/home/david/lib/libxml2.so /home/david/lib/libfreetype.so
-lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lcairo -lXpm -lfontconfig
-lpng12 -lsqlite3 -lodbc -lodbcinst -ljpeg -lpng -lpq -lpthread -lSM
-lICE -lX11 -lidn -lldap -lrt -lssl -lcrypto -ldl -lz -lbz2 -Wl,-rpath
-Wl,/home/david/lib
./.libs/libmapserver.so: undefined reference to `__sync_sub_and_fetch_4'
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
I originally got this error message: /usr/bin/ld: warning:
libcurl.so.3, needed by /home/david/lib/libgdal.so, may conflict with
libcurl.so.4 so I installed gdal from trunk, and reinstalled freetype,
giflib and libcurl
I've also attached the output from my ./configure command:
-------------- Compiler Info -------------
C compiler: gcc -g -Wall -Wdeclaration-after-statement
C++ compiler: g++ -g -Wall
Debug: -g
Generic NINT:
-------------- Renderer Settings ---------
OpenGL support:
zlib support:
png support: -DUSE_PNG
gif support: -DUSE_GIF
jpeg support: -DUSE_JPEG
freetype support: -DUSE_FREETYPE
iconv support: -DUSE_ICONV
AGG support: internal
GD support: -DUSE_GD -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_GIF
Cairo (SVG,PDF) support: -DUSE_CAIRO
Cairo SVG symbol support:
KML support: -DUSE_KML
-------------- Support Libraries ---------
Proj.4 support: -DUSE_PROJ
Proj Fastpaths:
Libxml2 support: -DUSE_LIBXML2
FriBidi support:
Curl support: -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH
FastCGI support:
Exempi support:
Threading support:
GEOS support: -DUSE_GEOS
XML Mapfile support:
XSLT support:
EXSLT support:
-------------- Data Format Drivers -------
PostGIS support: -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
ArcSDE support:
OGR support: -DUSE_OGR
GDAL support: -DUSE_GDAL
Oracle Spatial support:
-------------- OGC Services --------------
WMS Server: -DUSE_WMS_SVR
WMS Client: -DUSE_WMS_LYR
WFS Server: -DUSE_WFS_SVR
WFS Client: -DUSE_WFS_LYR
WCS Server: -DUSE_WCS_SVR
SOS Server:
-------------- MapScript -----------------
PHP MapScript: yes
Python MapScript: no
-David
