[mapserver-users] TinyOWS wrong call in OpenLayers - 'InvalidParameterValue' - XML request isn't valid
Riccardo Gaeta
riccardog79 at gmail.com
Thu Oct 18 02:33:42 PDT 2012
I'm testing the pevious version for windows, the 0.9.0, and it doesn't work
as well.
But from the Windows shell when I launch:
.\tinyows.exe --check
With this 0.9 version I get the first rows that seems to be good:
TinyOWS version: 0.9.0
FCGI support: Yes
Config File Path: @prefix@/tinyows/config.xml
Then the program "tinyows.exe" crash and I've to close it. Strange!
But if I think that with the version 1.0 I just get:
<?xml version='1.0' encoding='UTF-8'?>
<ows:ExceptionReport
xmlns='http://www.opengis.net/ows'
xmlns:ows='http://www.opengis.net/ows'
xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
xsi:schemaLocation='http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd'
version='1.1.0' language='en'>
<ows:Exception exceptionCode='ErrorConfigFile' locator='parse_config_file'>
<ows:ExceptionText>Unable to open config file !</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
The message get with the version 0.9 sounds to me better!
Anyway it doesn't work as well because it crash also by browser...
2012/10/18 Riccardo Gaeta <riccardog79 at gmail.com>
> Ok.
> First of all I have to say that I use as Apache the
> EntrepriseDB-ApachePHP, installed by PostgreSQL "Application Stack
> Builder", I don't know if this could be the problem...
> Anyway, for Tinyows I unzip the file:
> tinyows-1.0.0rc3-ms4w3.0.zip
> Then:
> - I've moved the folder "tinyows" (with the folder "schema" and the
> "config.xml") in "C:\PostgreSQL\EnterpriseDB-ApachePHP"
> - I've moved the file "tinyows.exe" in
> "C:\PostgreSQL\EnterpriseDB-ApachePHP\apache\cgi-bin"
> - I've moved the file "http_tinyows.conf" in
> "C:\PostgreSQL\EnterpriseDB-ApachePHP\apache\conf\addons"
> - I've changed the content of the file "http_tinyows.conf" in:
> # set environment vars necessary for Tinyows:
> SetEnv TINYOWS_CONFIG_FILE
> "C:\PostgreSQL\EnterpriseDB-ApachePHP\tinyows\config.xml"
> SetEnv TINYOWS_SCHEMA_DIR
> "C:\PostgreSQL\EnterpriseDB-ApachePHP\tinyows\schema\"
> - I've added the follow lines at the end of the "httpd.conf":
> Alias /tinyows/ "C:\PostgreSQL\EnterpriseDB-ApachePHP\tinyows\"
> <Directory "C:\PostgreSQL\EnterpriseDB-ApachePHP\tinyows">
> AllowOverride None
> Options Indexes FollowSymLinks Multiviews
> Order allow,deny
> Allow from all
> </Directory>
> - In the head of the file "config.xml" I put:
> <tinyows online_resource="http://127.0.0.1:8080/cgi-bin/tinyows.exe"
> schema_dir="C:\PostgreSQL\EnterpriseDB-ApachePHP\apache\www\tinyows\schema\"
> log="C:\PostgreSQL\EnterpriseDB-ApachePHP\apache\logs\tinyows.log"
> log_level="7">
> Hope this could help.
> Now I'm trying to do some test with the older version 0.9.0, I'll let you
> know.
> Riccardo
> 2012/10/18 Olivier Courtin <olivier.courtin at gmail.com>
>> On Wed, Oct 17, 2012 at 2:09 PM, Riccardo Gaeta <riccardog79 at gmail.com>wrote:
>>> Thanks Olivier. It doesn't work anyway. I can see the layer "base" but
>>> not my tinyows layer...
>> Humm, could you give information on the way you install TinyOWS on your
>> Win32 ?
>> (looking for a way to reproduce this behaviour...)
>> Olivier
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121018/68aa5fae/attachment-0001.html>
