[mapserver-users] undefined reference to `__sync_sub_and_fetch_4'
Thiago Tiedtke dos Reis
tiedtke at gmail.com
Thu Oct 18 04:01:42 PDT 2012
I having the same problem when trying to compile the mapserver with
msys/mingw under Ms windows 7 32bit.
Regards,
Em 17/10/2012 14:32, "Umberto Nicoletti" <umberto.nicoletti at gmail.com>
escreveu:
> David,
> what is your os/platform?
> On Oct 17, 2012 6:30 PM, "David Quinn" <daithiquinn at gmail.com> wrote:
> > Hello List,
> > I'm getting the following error when I try to compile mapserver-6.2.0-rc1
> > $make
> > /bin/sh ./libtool --mode=link --tag=CXX g++ -rpath /home/david/lib
> > shp2img.lo libmapserver.la -o shp2img
> > libtool: link: g++ .libs/shp2img.o -o .libs/shp2img
> > ./.libs/libmapserver.so -L/home/david/lib /home/david/lib/libgd.so
> > -L/usr/lib /home/david/lib/libproj.so /home/david/lib/libgdal.so
> > -L/home/david -L/usr/kerberos/lib /usr/lib/libexpat.so
> > /home/david/lib/libgif.so /home/david/lib/libcurl.so
> > /home/david/lib/libgeos_c.so /home/david/lib/libgeos.so
> > /home/david/lib/libxml2.so /home/david/lib/libfreetype.so
> > -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lcairo -lXpm -lfontconfig
> > -lpng12 -lsqlite3 -lodbc -lodbcinst -ljpeg -lpng -lpq -lpthread -lSM
> > -lICE -lX11 -lidn -lldap -lrt -lssl -lcrypto -ldl -lz -lbz2 -Wl,-rpath
> > -Wl,/home/david/lib
> > ./.libs/libmapserver.so: undefined reference to `__sync_sub_and_fetch_4'
> > collect2: ld returned 1 exit status
> > make: *** [shp2img] Error 1
> > I originally got this error message: /usr/bin/ld: warning:
> > libcurl.so.3, needed by /home/david/lib/libgdal.so, may conflict with
> > libcurl.so.4 so I installed gdal from trunk, and reinstalled freetype,
> > giflib and libcurl
> > I've also attached the output from my ./configure command:
> > -------------- Compiler Info -------------
> > C compiler: gcc -g -Wall
> -Wdeclaration-after-statement
> > C++ compiler: g++ -g -Wall
> > Debug: -g
> > Generic NINT:
> > -------------- Renderer Settings ---------
> > OpenGL support:
> > zlib support:
> > png support: -DUSE_PNG
> > gif support: -DUSE_GIF
> > jpeg support: -DUSE_JPEG
> > freetype support: -DUSE_FREETYPE
> > iconv support: -DUSE_ICONV
> > AGG support: internal
> > GD support: -DUSE_GD -DUSE_GD_PNG -DUSE_GD_JPEG
> -DUSE_GD_GIF
> > Cairo (SVG,PDF) support: -DUSE_CAIRO
> > Cairo SVG symbol support:
> > KML support: -DUSE_KML
> > -------------- Support Libraries ---------
> > Proj.4 support: -DUSE_PROJ
> > Proj Fastpaths:
> > Libxml2 support: -DUSE_LIBXML2
> > FriBidi support:
> > Curl support: -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH
> > FastCGI support:
> > Exempi support:
> > Threading support:
> > GEOS support: -DUSE_GEOS
> > XML Mapfile support:
> > XSLT support:
> > EXSLT support:
> > -------------- Data Format Drivers -------
> > PostGIS support: -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
> > ArcSDE support:
> > OGR support: -DUSE_OGR
> > GDAL support: -DUSE_GDAL
> > Oracle Spatial support:
> > -------------- OGC Services --------------
> > WMS Server: -DUSE_WMS_SVR
> > WMS Client: -DUSE_WMS_LYR
> > WFS Server: -DUSE_WFS_SVR
> > WFS Client: -DUSE_WFS_LYR
> > WCS Server: -DUSE_WCS_SVR
> > SOS Server:
> > -------------- MapScript -----------------
> > PHP MapScript: yes
> > Python MapScript: no
> > -David
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121018/f4e7ab1a/attachment.html>
