[mapserver-users] mapscript - msProcessProjection()
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Oct 18 06:01:20 PDT 2012
On 12-10-17 4:08 PM, Mark Volz wrote:
> Hello,
> I am working on page that uses php mapscript. The code works fine on my development Apache/MS4W computer. I am having trouble getting it to work on a server that is using IIS/MS4W. I should note that server is running GeoMOOSE within the IIS/MS4W environment fine. Anyways the code crashes on "$sq_img = $map->drawquery(); // draw the image" and reports an error: Warning: [MapServer Error]: msProcessProjection(): No such file or directory.
> Any ideas how I can fix this problem?
Besides Brent's fix, when I work on IIS (with many mapfiles) I set a
Windows environment variable for PROJ_LIB (but always make sure to
manually reboot your Windows machine for this to take effect).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
