[mapserver-users] TinyOWS wrong call in OpenLayers - 'InvalidParameterValue' - XML request isn't valid
Riccardo Gaeta
riccardog79 at gmail.com
Mon Oct 22 07:55:00 PDT 2012
Hi all.
I have "quite" solved the problem.
I need just to load another OpenLayers.js built with inside the GML vector
style.
So I add on my .html file this row:
<script type="text/javascript" src="http://openlayers.org/dev/OpenLayers.js
"></script>
Obviously I've to load my layer not as a GeoJSON but as GML:
readFormat: new OpenLayers.Format.GML({
'internalProjection': new OpenLayers.Projection("EPSG:900913"),
'externalProjection': new OpenLayers.Projection("EPSG:900913")
Now it works!
Thanks at all,
Riccardo
P.S.: As GeoJSON I get the following error message (from FireBug of
Mozilla):
"JSON.parse: unexpected character"
"Uncaught SyntaxError: Unexpected token ] "
I don't know why. Anyway, for now is enough GML. Or if you know the reasons
I get this error could be interesting to know...
2012/10/18 Riccardo Gaeta <riccardog79 at gmail.com>
> I go to the link you suggest but I didn't find the rc4 version for windows
> to download...
> Anyway, I copy some dll (like gdal, geos,xercers,libxml2,etc) into my
> cgi-bin directory from a previous version of an Apache2 windows
> installation.
> And the error message change!
> Now I obtain (from tinyows.log):
> [ERROR] Element '{http://www.w3.org/2001/XMLSchema}import': Skipping
> import of schema located at '
> http://schemas.opengis.net/gml/2.1.2/feature.xsd' for the namespace '
> http://www.opengis.net/gml', since this namespace was already imported
> with the schema located at '
> http://127.0.0.1:8080/tinyows/schema/gml/2.1.2/feature.xsd'.
> [ERROR] Filter parameter doesn't validate WFS Schema
> On QGIS always work well.
> Mmmmhhhhhh....
> I suppose I have maybe 2 problem:
> 1-I need some dll library in window
> 2-the tinyows.exe of version 1.0.0rc3 is damaged in someway
> Thanks again for your help, any other tips is appreciated!
> riccardo
> 2012/10/18 Olivier Courtin <olivier.courtin at gmail.com>
>> 0.9 version is that old, and should not be used anymore, for any
>> reasons...
>> 1.0.0rc3, well was an rc, and several fixes was corrected before
>> launching 1.0.0
>> You could give a look at OSGeo4W as they provide a 1.0.0rc4 (yeap still
>> an rc)
>> http://trac.osgeo.org/osgeo4w/wiki/pkg-tinyows
>> But a real solution would be that someone take Win32 packaging in charge,
>> Also for information:
>> http://gis-lab.info/qa/tinyows-compile-vce-eng.html
>> Olivier
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121022/61acefcc/attachment.html>
