[mapserver-users] WMS server error. Invalid layer(s) given in the LAYERS parameter.
Mike Stoddart
stodge at gmail.com
Fri Oct 26 06:18:04 PDT 2012
Thanks, I tried as you suggested after reading the documentation
WEB
IMAGEPATH "/opt/test/static/ms_tmp"
IMAGEURL "/media/ms_tmp/"
METADATA
ows_enable_request "*"
END
END # WEB
But I still get the same error.
Thanks
Mike
On Thu, Oct 25, 2012 at 5:02 PM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi>wrote:
> Hi,
> Perhaps you have not added
> "ows_enable_request" "*"
> into your mapfile. Search and read the migration guide if this happens to
> be the reason for the trouble.
> Mapserver web site should be updated at least.
> -Jukka Rahkonen-
> ________________________________
> Mike Stoddart wrote:
> > I'm using MapServer 6.0.1 on Fedora 16 and I'm having a weird layer
> issue. We're trying to port our application from MapServer 5 -> 6 and we're
> seeing the error:
> > I can re-create the problem using Python MapScript and an example map
> file from the MapServer website. The map file is:
> MAP
> NAME "sample"
> STATUS ON
> SIZE 600 400
> EXTENT -180 -90 180 90
> UNITS DD
> IMAGECOLOR 255 255 255
> FONTSET "/opt/test/conf/fonts.list"
> # Start of web interface definition
> WEB
> END # WEB
> # Start of layer definitions
> LAYER
> NAME 'inline_circles'
> TYPE CIRCLE
> STATUS on
> FEATURE
> POINTS
> 74.01 -53.8
> 110.7 -22.16
> END
> END
> CLASS
> STYLE
> COLOR 0 0 255
> END
> END
> END
> END # MAP
> If I use the following Python:
> import mapscript
> f = "<path to map file>"
> m = mapscript.mapObj(f)
> r = mapscript.OWSRequest()
> r.setParameter('LAYERS', 'inline_circle')
> m.loadOWSParameters(r)
> I get:
> <ServiceExceptionReport version="1.1.1">
> <ServiceException code="LayerNotDefined">
> msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the
> LAYERS parameter.
> </ServiceException>
> </ServiceExceptionReport>
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File "/usr/lib64/python2.7/site-packages/mapscript.py", line 1623, in
> loadOWSParameters
> def loadOWSParameters(*args): return
> _mapscript.mapObj_loadOWSParameters(*args)
> _mapscript.MapServerError: msWMSLoadGetMapParams(): WMS server error.
> So it doesn't think the layer exists. If I check the layer's status:
> m.getLayer(0).status
> 0
> The layer is disabled? So I'm assuming something is amiss in my map file
> but I just can't see it. Am I missing something obvious?
> Thanks
> Mike
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121026/b95db2f3/attachment.html>
