[mapserver-users] filter expression and boolean field
Havard Tveite
havard.tveite at umb.no
Fri Oct 26 07:45:28 PDT 2012
I am also be interested in learning how to use boolean
attributes in filter expressions.
I have also tried to get a filter expression with a
boolean attribute to work, but have had no luck. My
data source was PostGIS.
I did a workaround in SQL to get integers instead
(CASE WHEN booleanvariable = 'f' then 0 else 1).
Håvard
On 10/26/2012 3:26 PM, Brian Fischer wrote:
> Hi,
> I am trying to use a filter expression to only display features where a value is true in a Boolean field coming from an MSSQL Spatial datasource. It seems like every syntax I try MapServer comes back with “An expression of non-boolean type specified in a context where a condition is expected”
> I have tried a number of different combinations. How do you specify a Boolean expression? Has anyone got a Boolean field type to work from a database source? If so what expression did you use?
> Thanks!
> *Brian Fischer, CFM***
> Principal | GIS Project Manager
> *O* 763.493.4522 | *D* 763.493.6664 | *M* 763.229.2734
> cid:image001.jpg at 01CC3702.356B79C0
> 6901 E Fish Lake Rd. , Suite 140 • Maple Grove, MN • 55369
> *www.houstoneng.com* <http://www.houstoneng.com/>* ***
> This entire message (including all forwards and replies) and any attachments are for the sole use of the intended recipient(s) and may contain proprietary, confidential, trade secret, work-product, attorney-client or privileged information. Any unauthorized review, use, disclosure or distribution is prohibited and may be a violation of law. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
