[mapserver-users] securing mapserver layers
Lars Lingner
gislars+list at googlemail.com
Mon Aug 12 01:39:15 PDT 2013
Hello,
i'm having a similar use case at the moment. For the authorizaion and
authentication I'm using MapProxy [1].
Basically it is a proxy your users will query. The proxy itself uses
MapServer as source.
Your can restrict whole WMS, layers or even regions, defined by
bbox/shapefile.
It is running well with MapServer and I was able to set it up by using
the online documentation.
Lars
[1] http://mapproxy.org/docs/nightly/auth.html
