[mapserver-users] Angle Follow will accept only simple linestring don't MultiLinestring ?
Andrea Peri
aperi2007 at gmail.com
Tue Aug 13 09:26:04 PDT 2013
The two label are at different max/min scaledenominator.
The goal is to have little label size at low scales and bigger font size at
bigger scales.
However only one lable is active at one scale level.
Is this incompatible with "follow" ?
2013/8/13 thomas bonfort <thomas.bonfort at gmail.com>
> why the double label? they seem to be the same, but in any case
> multiple labels are not supported for FOLLOW.
> On 13 August 2013 18:08, Andrea Peri <aperi2007 at gmail.com> wrote:
> > I'm using spatialite 4.1.1,
> > so use ogr to access the db.
> > LAYER
> > NAME "rt_topogr.50k.etichette.topon_idro_50k"
> > STATUS OFF
> > EXTENT 1554750.74 4678325.52 1771722.76 4924791.90
> > TYPE LINE
> > CONNECTIONTYPE OGR
> > CONNECTION "/path-to-spatialite/zz_topografica.sqlite"
> > DATA "select PK_UID_2, TOPO_OK, GEOMETRY from topon_idro_50k"
> > PROJECTION
> > "+init=epsg:3003 +towgs84=0,0,0,0,0,0,0"
> > END
> > METADATA
> > "wms_title" "topon_idro_50k"
> > "wms_extent" "1554750.74 4678325.52 1771722.76 4924791.90"
> > END
> > LABELCACHE ON
> > MAXSCALEDENOM 60100
> > MINSCALEDENOM 1
> > CLASS
> > NAME ''
> > MAXSCALEDENOM 60100
> > MINSCALEDENOM 1
> > LABEL
> > TEXT '[TOPO_OK]'
> > COLOR 0 85 255
> > OUTLINECOLOR 212 255 255
> > OUTLINEWIDTH 1
> > MAXSCALEDENOM 60100
> > MINSCALEDENOM 40100
> > FONT "LiberationSans-Regular"
> > TYPE truetype
> > SIZE 7
> > ANGLE FOLLOW
> > OFFSET 15 99
> > POSITION auto
> > PRIORITY 10
> > MAXOVERLAPANGLE 180.0
> > BUFFER 1
> > FORCE OFF
> > PARTIALS FALSE
> > MINDISTANCE 200
> > END
> > LABEL
> > TEXT '[TOPO_OK]'
> > COLOR 0 85 255
> > OUTLINEWIDTH 1
> > MAXSCALEDENOM 40100
> > MINSCALEDENOM 1
> > TYPE truetype
> > SIZE 9
> > ANGLE FOLLOW
> > OFFSET 15 99
> > POSITION auto
> > PRIORITY 10
> > BUFFER 1
> > FORCE OFF
> > PARTIALS FALSE
> > MINDISTANCE 200
> > END
> > END
> > END
> >> there's something strange in your error message... the
> >> singleSidedBuffer stuff is in GEOS, and should have nothing to do in
> >> msOGRFileNextShape. post your whole mapfile layer.
> >> On 13 August 2013 17:42, Andrea Peri <aperi2007 at gmail.com> wrote:
> >> > Hi,
> >> > I tested trasforming the multilinestring dataset in a linestring
> dataset
> >> > but
> >> > the error is still here.
> >> > msDrawMap(): Image handling error. Failed to draw layer named
> >> > 'rt_topogr.50k.etichette.topon_idro_50k'.
> >> > msOGRFileNextShape(): OGR error. IllegalArgumentException:
> >> > BufferBuilder::bufferLineSingleSided only accept linestrings
> >> > So it is not really due to a multilinestring vs linestring question.
> >> > The quest carry on.
> >> > 2013/8/13 Andrea Peri <aperi2007 at gmail.com>
> >> >> Hi,
> >> >> Try.ing to set a label on a MULTILINESTRING dataset.
> >> >> I set a label with Follow capability.
> >> >> ANGLE FOLLOW
> >> >> But I'm having this error:
> >> >> Is the Follow compatible with a MultiLinestring dataset or need only
> >> >> simple linestrings ?
> >> >> Thx,
> >> >> Andrea Peri
> >> >> qwerty àèìòù
> >> > Andrea Peri
> >> > qwerty àèìòù
> >> > _______________________________________________
> >> > mapserver-users mailing list
> >> > mapserver-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > Andrea Peri
> > qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130813/70fe6ed9/attachment-0001.html>
