[mapserver-users] Angle Follow will accept only simple linestring don't MultiLinestring ?
Andrea Peri
aperi2007 at gmail.com
Tue Aug 13 09:22:03 PDT 2013
Hi Jukka,
I check for this critical questions:
unfortunately none of all them is in the dataset.
No invalid geometry, neither null geometry, neither Empty geometry.
Andrea.
2013/8/13 Rahkonen Jukka <jukka.rahkonen at mmmtike.fi>
> Hi,
> What if there happens to be empty/null geometries in your source data? I
> guess you can add "AND geometry in not NULL" and perhaps even "AND
> IsValid(geometry)=1" to your DATA line.
> -Jukka Rahkonen-
> ________________________________
> Andrea Peri wrote:
> > I'm using spatialite 4.1.1,
> > so use ogr to access the db.
> LAYER
> NAME "rt_topogr.50k.etichette.topon_idro_50k"
> STATUS OFF
> EXTENT 1554750.74 4678325.52 1771722.76 4924791.90
> TYPE LINE
> CONNECTIONTYPE OGR
> CONNECTION "/path-to-spatialite/zz_topografica.sqlite"
> DATA "select PK_UID_2, TOPO_OK, GEOMETRY from topon_idro_50k"
> PROJECTION
> "+init=epsg:3003 +towgs84=0,0,0,0,0,0,0"
> END
> METADATA
> "wms_title" "topon_idro_50k"
> "wms_extent" "1554750.74 4678325.52 1771722.76 4924791.90"
> END
> LABELCACHE ON
> MAXSCALEDENOM 60100
> MINSCALEDENOM 1
> CLASS
> NAME ''
> MAXSCALEDENOM 60100
> MINSCALEDENOM 1
> LABEL
> TEXT '[TOPO_OK]'
> COLOR 0 85 255
> OUTLINECOLOR 212 255 255
> OUTLINEWIDTH 1
> MAXSCALEDENOM 60100
> MINSCALEDENOM 40100
> FONT "LiberationSans-Regular"
> TYPE truetype
> SIZE 7
> ANGLE FOLLOW
> OFFSET 15 99
> POSITION auto
> PRIORITY 10
> MAXOVERLAPANGLE 180.0
> BUFFER 1
> FORCE OFF
> PARTIALS FALSE
> MINDISTANCE 200
> END
> LABEL
> TEXT '[TOPO_OK]'
> COLOR 0 85 255
> OUTLINEWIDTH 1
> MAXSCALEDENOM 40100
> MINSCALEDENOM 1
> TYPE truetype
> SIZE 9
> ANGLE FOLLOW
> OFFSET 15 99
> POSITION auto
> PRIORITY 10
> BUFFER 1
> FORCE OFF
> PARTIALS FALSE
> MINDISTANCE 200
> END
> END
> END
> 2013/8/13 thomas bonfort <thomas.bonfort at gmail.com<mailto:
> thomas.bonfort at gmail.com>>
> there's something strange in your error message... the
> singleSidedBuffer stuff is in GEOS, and should have nothing to do in
> msOGRFileNextShape. post your whole mapfile layer.
> On 13 August 2013 17:42, Andrea Peri <aperi2007 at gmail.com<mailto:
> aperi2007 at gmail.com>> wrote:
> > Hi,
> > I tested trasforming the multilinestring dataset in a linestring dataset
> but
> > the error is still here.
> > msDrawMap(): Image handling error. Failed to draw layer named
> > 'rt_topogr.50k.etichette.topon_idro_50k'.
> > msOGRFileNextShape(): OGR error. IllegalArgumentException:
> > BufferBuilder::bufferLineSingleSided only accept linestrings
> > So it is not really due to a multilinestring vs linestring question.
> > The quest carry on.
> > 2013/8/13 Andrea Peri <aperi2007 at gmail.com<mailto:aperi2007 at gmail.com>>
> >> Hi,
> >> Try.ing to set a label on a MULTILINESTRING dataset.
> >> I set a label with Follow capability.
> >> ANGLE FOLLOW
> >> But I'm having this error:
> >> Is the Follow compatible with a MultiLinestring dataset or need only
> >> simple linestrings ?
> >> Thx,
> >> Andrea Peri
> >> qwerty àèìòù
> > Andrea Peri
> > qwerty àèìòù
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130813/fe2fb1d6/attachment.html>
