[mapserver-users] Angle Follow will accept only simple linestring don't MultiLinestring ?
thomas bonfort
thomas.bonfort at gmail.com
Tue Aug 13 09:28:32 PDT 2013
yes, that's incompatible. use multiple scale-dependant classes for now
On 13 August 2013 18:26, Andrea Peri <aperi2007 at gmail.com> wrote:
> The two label are at different max/min scaledenominator.
> The goal is to have little label size at low scales and bigger font size at
> bigger scales.
> However only one lable is active at one scale level.
> Is this incompatible with "follow" ?
> 2013/8/13 thomas bonfort <thomas.bonfort at gmail.com>
>> why the double label? they seem to be the same, but in any case
>> multiple labels are not supported for FOLLOW.
>> On 13 August 2013 18:08, Andrea Peri <aperi2007 at gmail.com> wrote:
>> > I'm using spatialite 4.1.1,
>> > so use ogr to access the db.
>> > LAYER
>> > NAME "rt_topogr.50k.etichette.topon_idro_50k"
>> > STATUS OFF
>> > EXTENT 1554750.74 4678325.52 1771722.76 4924791.90
>> > TYPE LINE
>> > CONNECTIONTYPE OGR
>> > CONNECTION "/path-to-spatialite/zz_topografica.sqlite"
>> > DATA "select PK_UID_2, TOPO_OK, GEOMETRY from topon_idro_50k"
>> > PROJECTION
>> > "+init=epsg:3003 +towgs84=0,0,0,0,0,0,0"
>> > END
>> > METADATA
>> > "wms_title" "topon_idro_50k"
>> > "wms_extent" "1554750.74 4678325.52 1771722.76 4924791.90"
>> > END
>> > LABELCACHE ON
>> > MAXSCALEDENOM 60100
>> > MINSCALEDENOM 1
>> > CLASS
>> > NAME ''
>> > MAXSCALEDENOM 60100
>> > MINSCALEDENOM 1
>> > LABEL
>> > TEXT '[TOPO_OK]'
>> > COLOR 0 85 255
>> > OUTLINECOLOR 212 255 255
>> > OUTLINEWIDTH 1
>> > MAXSCALEDENOM 60100
>> > MINSCALEDENOM 40100
>> > FONT "LiberationSans-Regular"
>> > TYPE truetype
>> > SIZE 7
>> > ANGLE FOLLOW
>> > OFFSET 15 99
>> > POSITION auto
>> > PRIORITY 10
>> > MAXOVERLAPANGLE 180.0
>> > BUFFER 1
>> > FORCE OFF
>> > PARTIALS FALSE
>> > MINDISTANCE 200
>> > END
>> > LABEL
>> > TEXT '[TOPO_OK]'
>> > COLOR 0 85 255
>> > OUTLINEWIDTH 1
>> > MAXSCALEDENOM 40100
>> > MINSCALEDENOM 1
>> > TYPE truetype
>> > SIZE 9
>> > ANGLE FOLLOW
>> > OFFSET 15 99
>> > POSITION auto
>> > PRIORITY 10
>> > BUFFER 1
>> > FORCE OFF
>> > PARTIALS FALSE
>> > MINDISTANCE 200
>> > END
>> > END
>> > END
>> >> there's something strange in your error message... the
>> >> singleSidedBuffer stuff is in GEOS, and should have nothing to do in
>> >> msOGRFileNextShape. post your whole mapfile layer.
>> >> On 13 August 2013 17:42, Andrea Peri <aperi2007 at gmail.com> wrote:
>> >> > Hi,
>> >> > I tested trasforming the multilinestring dataset in a linestring
>> >> > dataset
>> >> > but
>> >> > the error is still here.
>> >> > msDrawMap(): Image handling error. Failed to draw layer named
>> >> > 'rt_topogr.50k.etichette.topon_idro_50k'.
>> >> > msOGRFileNextShape(): OGR error. IllegalArgumentException:
>> >> > BufferBuilder::bufferLineSingleSided only accept linestrings
>> >> > So it is not really due to a multilinestring vs linestring question.
>> >> > The quest carry on.
>> >> > 2013/8/13 Andrea Peri <aperi2007 at gmail.com>
>> >> >> Hi,
>> >> >> Try.ing to set a label on a MULTILINESTRING dataset.
>> >> >> I set a label with Follow capability.
>> >> >> ANGLE FOLLOW
>> >> >> But I'm having this error:
>> >> >> Is the Follow compatible with a MultiLinestring dataset or need only
>> >> >> simple linestrings ?
>> >> >> Thx,
>> >> >> Andrea Peri
>> >> >> qwerty àèìòù
>> >> > Andrea Peri
>> >> > qwerty àèìòù
>> >> > _______________________________________________
>> >> > mapserver-users mailing list
>> >> > mapserver-users at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> > Andrea Peri
>> > qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
