[mapserver-users] ScribeUI: Possible segmentation fault on Ubuntu 12.04
Luís de Sousa
luis.a.de.sousa at gmail.com
Mon Aug 19 06:52:21 PDT 2013
Hi Jessica, you'll find below the contents of the files you ask plus the
Apache config.
Here's an example of an address ScirbeUI is trying to access that doesn't
exist:
http://localhost/static/css/reset.css
I believe it should be:
http://localhost/ScribeUI/static/css/reset.css
But I can't see where this particular path could be configured.
Thanks for helping,
Luís
# config.py
#Replace 0.0.0.0 with your server's ip or hostname
#Examples: "127.0.0.1", "my.host.com"
ip = "0.0.0.0"
# runserver.wsgi
from runserver.py import app as application
import sys
#Replace <scribeui_path> with the path to the root of your scribeui
installation
#Example: /opt/ScribeUI/application/runserver.py
sys.path.insert(0,'/opt/ScribeUI/application/runserver.py')
WSGIScriptAlias /ScribeUI /opt/ScribeUI/application/runserver.py
# ScribeUI.conf
#ScribeUI
AddType text/html .py
<Directory /opt/ScribeUI/application/templates>
Order deny,allow
Allow from all
</Directory>
Alias /ScribeUI/download/ "/opt/ScribeUI/application/www/"
<Directory "/opt/ScribeUI/application/www/">
AllowOverride None
Options Indexes FollowSymLinks Multiviews
Order allow,deny
Allow from all
</Directory>
View this message in context: http://osgeo-org.1560.x6.nabble.com/ScribeUI-Possible-segmentation-fault-on-Ubuntu-12-04-tp5072423p5073155.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
