[mapserver-users] Create imageObject failed in python binding.
Umberto Nicoletti
umberto.nicoletti at gmail.com
Mon Aug 19 00:45:43 PDT 2013
Shawn,
I have briefly checked the python mapscript sources and I am afraid the you
might have hit a bug.
Python mapscript has a special, more pythonic imageObj constructor which
seems to depend heavily on GD code
and that possibily explains the error you are experiencing.
Would you mind opening an issue at:
https://github.com/mapserver/mapserver/issues/new
Please state the mapserver version and, if built from sources, the options
used.
It would greatly speed up the resolution process if you could build
mapserver/mapscript from the git sources.
BR,
Umberto
On Sun, Aug 18, 2013 at 4:59 AM, Shawn Gao <gaohawk at gmail.com> wrote:
> Hi, All,
> Official document on mapserver site said use following way to create an
> imageObject instance in python. look at this link<http://mapserver.org/mapscript/mapscript.html#imageobj>
> new imageObj( int width, int height [, outputFormatObj<http://mapserver.org/mapscript/mapscript.html#outputformatobj> format=NULL
> [, string filename=NULL ] ] ) : imageObj
> So I create imageObject in Python by this,
> mapscript.imageObj(100,100,"GD/PNG", '
> http://mapserver.org/_static/banner.png')
> But get error, "Segmentation fault (core dumped)".
> Then I check the test case of python binding. The test case for
> imageObject is in imagetest.py. I try it firstly. Then many cases failed,
> include the case for create imageObject instance. I found the create method
> in test script is in other way.
> def testConstructorUrlStream(self):
> """imageObj with a URL stream works"""
> url = urllib.urlopen('http://mapserver.org/_static/banner.png')
> imgobj = mapscript.imageObj(url, 'GD/JPEG')
> assert imgobj.thisown == 1
> assert imgobj.height == 68
> assert imgobj.width == 439
> imgobj.save('testConstructorUrlStream.jpg')
> What's the correct way to create an imageObject from url or file?
> Thanks,
> Shawn
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130819/c8b8b5b5/attachment.html>
