[mapserver-users] ScribeUI: Possible segmentation fault on Ubuntu 12.04
Jessica Lapointe
jlapointe at mapgears.com
Mon Aug 19 07:16:42 PDT 2013
Hi Luis,
You are right that the url should be localhost/ScribeUI/static.
In your config.py file, this ip = "0.0.0.0" should be the domain you
access the app with, in your case, it should be ip = "localhost"
After changing this the easiest way to see your changes instantly will
be to restart apache, because otherwise mod_wsgi will not necessarily
acknowledge your changes immediately.
Thank you,
Jessica
On Mon, Aug 19, 2013 at 9:52 AM, Luís de Sousa
<luis.a.de.sousa at gmail.com> wrote:
> Hi Jessica, you'll find below the contents of the files you ask plus the
> Apache config.
> Here's an example of an address ScirbeUI is trying to access that doesn't
> exist:
> http://localhost/static/css/reset.css
> I believe it should be:
> http://localhost/ScribeUI/static/css/reset.css
> But I can't see where this particular path could be configured.
> Thanks for helping,
> Luís
> # config.py
> #Replace 0.0.0.0 with your server's ip or hostname
> #Examples: "127.0.0.1", "my.host.com"
> ip = "0.0.0.0"
> # runserver.wsgi
> from runserver.py import app as application
> import sys
> #Replace <scribeui_path> with the path to the root of your scribeui
> installation
> #Example: /opt/ScribeUI/application/runserver.py
> sys.path.insert(0,'/opt/ScribeUI/application/runserver.py')
> WSGIScriptAlias /ScribeUI /opt/ScribeUI/application/runserver.py
> # ScribeUI.conf
> #ScribeUI
> AddType text/html .py
> <Directory /opt/ScribeUI/application/templates>
> Order deny,allow
> Allow from all
> </Directory>
> Alias /ScribeUI/download/ "/opt/ScribeUI/application/www/"
> <Directory "/opt/ScribeUI/application/www/">
> AllowOverride None
> Options Indexes FollowSymLinks Multiviews
> Order allow,deny
> Allow from all
> </Directory>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/ScribeUI-Possible-segmentation-fault-on-Ubuntu-12-04-tp5072423p5073155.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
