[mapserver-users] ScribeUI: Possible segmentation fault on Ubuntu 12.04
Luís de Sousa
luis.a.de.sousa at gmail.com
Tue Aug 20 00:40:12 PDT 2013
On 19 August 2013 16:16, Jessica Lapointe <jlapointe at mapgears.com> wrote:
> Hi Luis,
> You are right that the url should be localhost/ScribeUI/static.
> In your config.py file, this ip = "0.0.0.0" should be the domain you
> access the app with, in your case, it should be ip = "localhost"
Hi again Jessica,
I tried with "localhost" and "localhost/ScribeUI", but in both cases it
tries to load the css and js files from "localhost/static".
Thanks,
Luís
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130820/271626dd/attachment.html>
