[mapserver-users] Projections and raster files
David Power
David.Power at cs.ox.ac.uk
Thu Aug 29 10:18:46 PDT 2013
Thanks David,
Using the correct units seems to have fixed the problem.
@Jeff : Thanks for pointer, now that I have re-read it all makes sense
Cheers
David
On 29 Aug 2013, at 16:43, Fawcett, David (MNIT) wrote:
> David,
> Take a look at the map extent and units. They should be the units used by your output spatial reference system.
> In your current map file, you have DD for the units, for 3857, they should be meters. You will also want to express your extent in 3857 coords.
> David.
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of David Power
> Sent: Thursday, August 29, 2013 10:01 AM
> To: MapserverList OSGEO
> Subject: [mapserver-users] Projections and raster files
> Hello,
> I have a number of geotiffs which are currently using epsg:4326 and I would like to output a region using epsg:3857.
> I am new to mapserver but from what I have read the way achieve this is by setting the projection of the map to epsg:3857 and the layer to epsg:4326.
> When I set the projections to the same value I get the output I expect without a problem, if I set the projections to different values I do not get an error but the output is blank.
> To make life more complicated I am using mapscript via the Java swig interface, the version of mapserver I am using is mapserver 6.1.2.1 which I built from source.
> If anybody has any advice I would be most grateful.
> David
> gdalinfo gives the following information about one of the files:
> Driver: GTiff/GeoTIFF
> Files: globcover_n10e005.tif
> Size is 7200, 7200
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> Origin = (5.000000000000000,9.999999999999615)
> Pixel Size = (0.000138888888889,-0.000138888888889)
> Metadata:
> DataType=Generic
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 5.0000000, 10.0000000) ( 5d 0'0.00"E, 10d 0'0.00"N)
> Lower Left ( 5.0000000, 9.0000000) ( 5d 0'0.00"E, 9d 0'0.00"N)
> Upper Right ( 6.0000000, 10.0000000) ( 6d 0'0.00"E, 10d 0'0.00"N)
> Lower Right ( 6.0000000, 9.0000000) ( 6d 0'0.00"E, 9d 0'0.00"N)
> Center ( 5.5000000, 9.5000000) ( 5d30'0.00"E, 9d30'0.00"N)
> Band 1 Block=7200x128 Type=Byte, ColorInterp=Gray
> NoData Value=0
> The map file is built programmatically, the following is the result of saving the map object to file:
> MAP
> EXTENT 5 9.9 5.1 10
> IMAGETYPE "png"
> NAME "blank"
> SIZE 800 800
> STATUS ON
> UNITS DD
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE RGB
> TRANSPARENT FALSE
> END # OUTPUTFORMAT
> PROJECTION
> "init=epsg:3857"
> END # PROJECTION
> LEGEND
> KEYSIZE 20 10
> KEYSPACING 5 5
> LABEL
> SIZE MEDIUM
> OFFSET 0 0
> SHADOWSIZE 1 1
> TYPE BITMAP
> END # LABEL
> STATUS OFF
> END # LEGEND
> QUERYMAP
> SIZE -1 -1
> STATUS OFF
> STYLE HILITE
> END # QUERYMAP
> SCALEBAR
> INTERVALS 4
> LABEL
> SIZE MEDIUM
> OFFSET 0 0
> SHADOWSIZE 1 1
> TYPE BITMAP
> END # LABEL
> SIZE 200 3
> STATUS OFF
> UNITS MILES
> END # SCALEBAR
> WEB
> END # WEB
> LAYER
> DATA "/home/leftworker/data/landcover/lefttiles/n10/globcover_n10e005.tif"
> NAME "n10e005"
> PROJECTION
> "init=epsg:4326"
> END # PROJECTION
> STATUS ON
> TILEITEM "location"
> TYPE RASTER
> UNITS DD
> END # LAYER
> END # MAP
> Dr David J Power
> Research Officer
> Department of Computer Science
> University of Oxford
> tel: 01865 283670
> email: David.Power at cs.ox.ac.uk
Dr David J Power
Research Officer
tel: 01865 283670
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130829/b03f486b/attachment-0001.html>
