[mapserver-users] Installing MapServer 6.2 on IIS7.5
Neil Crisp
neil_crisp at technologyonecorp.com
Tue Feb 12 21:25:19 PST 2013
Hi Michael,
That will be very helpful, as I am also on 2008 R2. I am working on a
Windows 7 laptop that is connected to a 2008 R2 Amazon Cloud instance and
could not understand why I could not follow some of Donald's very easy
instructions. Then I tried it on my laptop successfully and realised the
difference between operating systems.
Cheers,
Neil.
On Wed, Feb 13, 2013 at 3:09 PM, Michael Hinke <michaelhinke at gmail.com>wrote:
> I am working through this now on IIS 7.5, 2008 R2. I will contribute. I
> miss CentOS. M.
> On Tue, Feb 12, 2013 at 9:26 PM, Neil Crisp <
> neil_crisp at technologyonecorp.com> wrote:
>> Donald, Umberto,
>> Thanks for your help. I am still working through the steps with minor
>> modifications to suit my application and making notes as I go, I will let
>> you know how I go.
>> Cheers,
>> Neil.
>> On Tue, Feb 12, 2013 at 7:06 PM, Donald Kerr <donald.kerr at dkerr.co.uk>wrote:
>>> Thanks, Umberto.****
>>> As I said to Neil, they’re very rough. Neil can maybe neaten them up a
>>> bit whilst he’s going through the process of installing on his machine.
>>> I’ll do the same when I next work on a non- XP machine.****
>>> Regards,****
>>> Donald****
>>> *From:* Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
>>> *Sent:* 12 February 2013 08:47
>>> *To:* Donald Kerr
>>> *Cc:* Neil Crisp; mapserver
>>> *Subject:* Re: [mapserver-users] Installing MapServer 6.2 on IIS7.5****
>>> Saved you both some time and copied your notes in the wiki:****
>>> https://github.com/mapserver/mapserver/wiki/Installing-mapserver-under-IIS
>>> Cheers,****
>>> Umberto****
>>> On Tue, Feb 12, 2013 at 9:20 AM, Donald Kerr <donald.kerr at dkerr.co.uk>
>>> wrote:****
>>> Neil,****
>>> I have some rough notes for my set up (Classic ASP website wit
>>> Openlayers – Mapserver WMS/WFS) as follows:****
>>> 1. IIS****
>>> a. Click Start, Control Panel, Programs, Turn Windows features on
>>> or off.****
>>> b. Select Internet Information Services.****
>>> c. Select Web Management Tools then select IIS Management Consule.
>>> d. Select World Wide Web Services****
>>> e. In Application development Features, select ASP, CGI, ISAPI
>>> Extensions, ISAPI Filters and Server-Side Includes.****
>>> f. In Common HTTP Features, select Default Document, HTTP
>>> Errors, HTTP Redirection and Static Content.****
>>> g. In Health and Diagnostics, select HTTP Logging and Request
>>> Monitor.****
>>> h. In Performance Features, select Static Content Compression.****
>>> i. In Security, select Request Filtering.****
>>> j. Navigate to http://localhost – An IIS welcome page should be
>>> shown.****
>>> k. Run inetmgr.****
>>> l. Highlight Default Web Site under Sites the right-click,
>>> Manage Web Site then click Advanced Settings. Change the physical path to
>>> d:\vmds\web\.****
>>> m. Double-click ASP in the centre panel of IIS Manager and ensure
>>> the following are set:****
>>> i. Enable Parent
>>> Paths****
>>> n. Click on Application Pools in the left hand panel of IIS
>>> Manager, click DefaultAppPool in the centre panel then click advanced
>>> settings in the right hand panel. Ensure that Enable 32-Bit Applications is
>>> set to True.****
>>> o. Create the following virtual directories in IIS:****
>>> i. cgi-bin
>>> d:\mapserver\cgi-bin (Neil, will probably be MS4W
>>> cgi-bin?)****
>>> ii. mapserver
>>> d:\mapserver\wwwroot (Neil, you will probably not require this)****
>>> p. Mapserver via FastCGI****
>>> i. Click on Default Web Site then
>>> double-click Handler Mappings in the centre panel.****
>>> ii. In the Actions Pane, click Add
>>> Module Mapping then set the following:****
>>> 1. Request path: *.exe****
>>> 2. Module: FastCgiModule****
>>> 3. Executable: d:\mapserver\cgi-bin\mapserv.exe****
>>> 4. Name: Mapserver via FastCGI****
>>> 5. Click on Request Restrictions and set the following:****
>>> a. Mapping Tab: Check “Invoke hander … “, then set for “File”.****
>>> b. Verbs Tab: “One of the following …”, enter “GET,HEAD,POST”.****
>>> c. Access Tab: Check “Execute”.****
>>> iii. Whilst the “Mapserver via
>>> FastCGI” handler mapping is highlighted, click on Edit feature permissions
>>> in the right hand panel then ensure that read, script and execute are
>>> checked.****
>>> For 64 bit Mapserver:****
>>> 2. Mapserver x64****
>>> a. Download x64 version of Mapserver from
>>> http://www.gisinternals.com/sdk/ ****
>>> b. Delete all existing files in d:\mapserver\cgi-bin\. These are
>>> the 32 bit Mapserver files from MS4W.****
>>> c. From the above download, copy all dlls from /bin/ to
>>> d:\mapserver\cgi-bin\.****
>>> d. Copy Mapserv.exe from /bin/ms/apps/ to d:\mapserver\cgi-bin****
>>> I hope this helps. If you write it up properly (something I should have
>>> done) then please send me a copy.****
>>> Regards,****
>>> Donald****
>>> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
>>> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Neil Crisp
>>> *Sent:* 12 February 2013 04:39
>>> *To:* mapserver-users at lists.osgeo.org
>>> *Subject:* [mapserver-users] Installing MapServer 6.2 on IIS7.5****
>>> I have successfully installed the latest release of MapServer (6.2beta4)
>>> on Windows via MS4W using Apache, but I need to get it running under
>>> IIS7.5. I haven't been having a good time.****
>>> The latest documentation (Release 6.3-dev) still has the old IIS 5
>>> documentation written by Debbie Paqurek back in 2005 and the latest other
>>> documentation I can find is for IIS 6 and is rather complex.****
>>> Has anyone successfully installed it on IIS7.5 and if so do you have a
>>> nice straightforward procedure for it? Something similar to Debbie's
>>> instructions, but up to date, would be great.****
>>> Thanks ****
>>> Neil Crisp.****
>>> Thanks ****
>>> Neil Crisp.****
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users****
>>> No virus found in this message.
>>> Checked by AVG - www.avg.com
>>> Version: 2013.0.2897 / Virus Database: 2639/6097 - Release Date: 02/11/13
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130213/ae84c009/attachment-0001.html>
