[mapserver-users] Installing MapServer 6.2 on IIS7.5
Michael Hinke
michaelhinke at gmail.com
Tue Feb 12 21:09:33 PST 2013
I am working through this now on IIS 7.5, 2008 R2. I will contribute. I
miss CentOS. M.
On Tue, Feb 12, 2013 at 9:26 PM, Neil Crisp <
neil_crisp at technologyonecorp.com> wrote:
> Donald, Umberto,
> Thanks for your help. I am still working through the steps with minor
> modifications to suit my application and making notes as I go, I will let
> you know how I go.
> Cheers,
> Neil.
> On Tue, Feb 12, 2013 at 7:06 PM, Donald Kerr <donald.kerr at dkerr.co.uk>wrote:
>> Thanks, Umberto.****
>> As I said to Neil, they’re very rough. Neil can maybe neaten them up a
>> bit whilst he’s going through the process of installing on his machine.
>> I’ll do the same when I next work on a non- XP machine.****
>> Regards,****
>> Donald****
>> *From:* Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
>> *Sent:* 12 February 2013 08:47
>> *To:* Donald Kerr
>> *Cc:* Neil Crisp; mapserver
>> *Subject:* Re: [mapserver-users] Installing MapServer 6.2 on IIS7.5****
>> Saved you both some time and copied your notes in the wiki:****
>> https://github.com/mapserver/mapserver/wiki/Installing-mapserver-under-IIS
>> Cheers,****
>> Umberto****
>> On Tue, Feb 12, 2013 at 9:20 AM, Donald Kerr <donald.kerr at dkerr.co.uk>
>> wrote:****
>> Neil,****
>> I have some rough notes for my set up (Classic ASP website wit Openlayers
>> – Mapserver WMS/WFS) as follows:****
>> 1. IIS****
>> a. Click Start, Control Panel, Programs, Turn Windows features on
>> or off.****
>> b. Select Internet Information Services.****
>> c. Select Web Management Tools then select IIS Management Consule.*
>> d. Select World Wide Web Services****
>> e. In Application development Features, select ASP, CGI, ISAPI
>> Extensions, ISAPI Filters and Server-Side Includes.****
>> f. In Common HTTP Features, select Default Document, HTTP Errors,
>> HTTP Redirection and Static Content.****
>> g. In Health and Diagnostics, select HTTP Logging and Request
>> Monitor.****
>> h. In Performance Features, select Static Content Compression.****
>> i. In Security, select Request Filtering.****
>> j. Navigate to http://localhost – An IIS welcome page should be
>> shown.****
>> k. Run inetmgr.****
>> l. Highlight Default Web Site under Sites the right-click, Manage
>> Web Site then click Advanced Settings. Change the physical path to
>> d:\vmds\web\.****
>> m. Double-click ASP in the centre panel of IIS Manager and ensure the
>> following are set:****
>> i. Enable Parent
>> Paths****
>> n. Click on Application Pools in the left hand panel of IIS
>> Manager, click DefaultAppPool in the centre panel then click advanced
>> settings in the right hand panel. Ensure that Enable 32-Bit Applications is
>> set to True.****
>> o. Create the following virtual directories in IIS:****
>> i. cgi-bin
>> d:\mapserver\cgi-bin (Neil, will probably be MS4W
>> cgi-bin?)****
>> ii. mapserver
>> d:\mapserver\wwwroot (Neil, you will probably not require this)****
>> p. Mapserver via FastCGI****
>> i. Click on Default Web Site then
>> double-click Handler Mappings in the centre panel.****
>> ii. In the Actions Pane, click Add
>> Module Mapping then set the following:****
>> 1. Request path: *.exe****
>> 2. Module: FastCgiModule****
>> 3. Executable: d:\mapserver\cgi-bin\mapserv.exe****
>> 4. Name: Mapserver via FastCGI****
>> 5. Click on Request Restrictions and set the following:****
>> a. Mapping Tab: Check “Invoke hander … “, then set for “File”.****
>> b. Verbs Tab: “One of the following …”, enter “GET,HEAD,POST”.****
>> c. Access Tab: Check “Execute”.****
>> iii. Whilst the “Mapserver via
>> FastCGI” handler mapping is highlighted, click on Edit feature permissions
>> in the right hand panel then ensure that read, script and execute are
>> checked.****
>> For 64 bit Mapserver:****
>> 2. Mapserver x64****
>> a. Download x64 version of Mapserver from
>> http://www.gisinternals.com/sdk/ ****
>> b. Delete all existing files in d:\mapserver\cgi-bin\. These are
>> the 32 bit Mapserver files from MS4W.****
>> c. From the above download, copy all dlls from /bin/ to
>> d:\mapserver\cgi-bin\.****
>> d. Copy Mapserv.exe from /bin/ms/apps/ to d:\mapserver\cgi-bin****
>> I hope this helps. If you write it up properly (something I should have
>> done) then please send me a copy.****
>> Regards,****
>> Donald****
>> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
>> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Neil Crisp
>> *Sent:* 12 February 2013 04:39
>> *To:* mapserver-users at lists.osgeo.org
>> *Subject:* [mapserver-users] Installing MapServer 6.2 on IIS7.5****
>> I have successfully installed the latest release of MapServer (6.2beta4)
>> on Windows via MS4W using Apache, but I need to get it running under
>> IIS7.5. I haven't been having a good time.****
>> The latest documentation (Release 6.3-dev) still has the old IIS 5
>> documentation written by Debbie Paqurek back in 2005 and the latest other
>> documentation I can find is for IIS 6 and is rather complex.****
>> Has anyone successfully installed it on IIS7.5 and if so do you have a
>> nice straightforward procedure for it? Something similar to Debbie's
>> instructions, but up to date, would be great.****
>> Thanks ****
>> Neil Crisp.****
>> Thanks ****
>> Neil Crisp.****
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users****
>> No virus found in this message.
>> Checked by AVG - www.avg.com
>> Version: 2013.0.2897 / Virus Database: 2639/6097 - Release Date: 02/11/13
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130212/2ee4c952/attachment-0001.html>
