[mapserver-users] mapserver 6.2.0 perl mapscript
Andy Colson
andy at squeakycode.net
Wed Feb 13 12:03:34 PST 2013
I was not doing a toplevel make install, so it didnt copy
libmapserver-6.2.0.so.
But, even after fixing my script, and installing:
usr/local/lib64/perl5/auto/mapscript/mapscript.so
usr/lib/libmapserver.la
usr/lib/libmapserver-6.2.0.so
I get the same error. Also:
ldd /usr/local/lib64/perl5/auto/mapscript/mapscript.so
doesn't show it using libmapserver.
-Andy
On 2/13/2013 1:30 PM, Umberto Nicoletti wrote:
> As of 6.2 mapscript is built as a shared lib and depends on mapserver
> which therefore must have been installed before.
> Umberto
> On Feb 13, 2013 8:27 PM, "Andy Colson" <andy at squeakycode.net
> <mailto:andy at squeakycode.net>> wrote:
> On 2/13/2013 1:19 PM, Umberto Nicoletti wrote:
> Did you run make install in the MapServer top level directory?
> Umberto
> On Feb 13, 2013 7:52 PM, "Andy Colson" <andy at squeakycode.net
> <mailto:andy at squeakycode.net <mailto:andy at squeakycode.net>>> wrote:
> Hi all,
> I'm having problems updating to 6.2.0. I can get perl
> mapscript to
> compile and install ok, but when I try to run anything:
> # perl dump.pl <http://dump.pl> <http://dump.pl>
> perl: symbol lookup error:
> /usr/local/lib64/perl5/auto/____mapscript/mapscript.so:
> undefined
> symbol: msSetup
> Any hints what might be wrong?
> Thanks for your time,
> -Andy
> I believe so. I'm actually making a slackware package (which I've
> done for 6.0.3 as well), and then I install the package.
> ls -l /usr/local/lib64/perl5/auto/__mapscript/mapscript.so
> does show it as todays date, so I'm pretty sure its new.
> I will go try to build it by hand and verify its not the packaging
> script that's a problem.
> -Andy
