[mapserver-users] mapserver 6.2.0 perl mapscript
Andy Colson
andy at squeakycode.net
Wed Feb 13 12:24:15 PST 2013
Ah. I figured it out.
I have to make and make install from top level first, so that
libmapserver.so is found, BEFORE I go into mapscript/perl and make/make
install.
That'll make building a package a little more difficult. Maybe if I
play with the path's I wont have to actually install it first.
Thanks for the help, though. It works now.
-Andy
On 2/13/2013 2:03 PM, Andy Colson wrote:
> I was not doing a toplevel make install, so it didnt copy
> libmapserver-6.2.0.so.
> But, even after fixing my script, and installing:
> usr/local/lib64/perl5/auto/mapscript/mapscript.so
> usr/lib/libmapserver.la
> usr/lib/libmapserver-6.2.0.so
> I get the same error. Also:
> ldd /usr/local/lib64/perl5/auto/mapscript/mapscript.so
> doesn't show it using libmapserver.
> -Andy
> On 2/13/2013 1:30 PM, Umberto Nicoletti wrote:
>> As of 6.2 mapscript is built as a shared lib and depends on mapserver
>> which therefore must have been installed before.
>> Umberto
>> On Feb 13, 2013 8:27 PM, "Andy Colson" <andy at squeakycode.net
>> <mailto:andy at squeakycode.net>> wrote:
>> On 2/13/2013 1:19 PM, Umberto Nicoletti wrote:
>> Did you run make install in the MapServer top level directory?
>> Umberto
>> On Feb 13, 2013 7:52 PM, "Andy Colson" <andy at squeakycode.net
>> <mailto:andy at squeakycode.net <mailto:andy at squeakycode.net>>>
>> wrote:
>> Hi all,
>> I'm having problems updating to 6.2.0. I can get perl
>> mapscript to
>> compile and install ok, but when I try to run anything:
>> # perl dump.pl <http://dump.pl> <http://dump.pl>
>> perl: symbol lookup error:
>> /usr/local/lib64/perl5/auto/____mapscript/mapscript.so:
>> undefined
>> symbol: msSetup
>> Any hints what might be wrong?
>> Thanks for your time,
>> -Andy
>> I believe so. I'm actually making a slackware package (which I've
>> done for 6.0.3 as well), and then I install the package.
>> ls -l /usr/local/lib64/perl5/auto/__mapscript/mapscript.so
>> does show it as todays date, so I'm pretty sure its new.
>> I will go try to build it by hand and verify its not the packaging
>> script that's a problem.
>> -Andy
> mapserver-users at lists.osgeo.org
