[mapserver-users] GetLegendGraphics don't return correctly the point symbol
Andrea Peri
aperi2007 at gmail.com
Tue Jan 8 04:35:53 PST 2013
oh oh. :)
I don't know it was existant. It is not in the documentation. :)
I try it instantly.
2013/1/8 thomas bonfort <thomas.bonfort at gmail.com>:
> then you need geomtransform centroid, no?
> On 8 January 2013 13:33, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Actually it is returning something like this:
>> OOOOOOO
>> OOOOOOO
>> OOOOOOO
>> OOOOOOO
>> These seem a polygon filled with many circles internally
>> Instead I would like to obtain something like this:
>> O
>>> what are you trying to obtain ?
>>> On 8 January 2013 13:16, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>> Hi,
>>>> many thx for response.
>>>>> Do you have a SIZEUNIT or SYMBOLSCALEDENOM set on your layer ?
>>>> No.
>>>>> Try increasing/setting your CLASS->STYLE->SIZEs, and remove the GEOMTRANSFORM
>>>> I try to removing the geomtransform, but it do disappeared all symbol
>>>> (ie polygons lesser then defined area).
>>>> But I see something of good try-ing to increase the size and also
>>>> adding a lesser than default outline.
>>>> ie:
>>>> size 6
>>>> with 0.1
>>>> and leaving the GeomTransform 'start'
>>>> It is surely better, but still it seem a polygon filled with many circles.
>>>> Instead my rendering is 1 only point for an entire polygon.
>>>> This seem not clearly understandable from the returned legend.
>>>> This is the result:
>>>> http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmstematici&service=wms&request=GetLegendGraphic&version=1.3.0&format=image/png&SLD_VERSION=1.1.0&layer=rt_tematici.idarch_a_1.rt&scale=60000
>>>> Many thx for hints,
>>>> Andrea.
>>>>> thomas
>>>>> On 8 January 2013 12:18, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>>>> Hi,
>>>>>> I have a polygon layer that at some scales try to render with a symbol.
>>>>>> To do this I define a specific symbol style:
>>>>>> SYMBOL
>>>>>> NAME "circlefill"
>>>>>> TYPE ellipse
>>>>>> POINTS
>>>>>> 1 1
>>>>>> END
>>>>>> FILLED true
>>>>>> ANCHORPOINT 0.5 0.5
>>>>>> END
>>>>>> And use this in the class definition as here where I put two class one
>>>>>> with a polygon rendering (when area bigger) and a second class with
>>>>>> point rendering when area is lower:
>>>>>> CLASS
>>>>>> NAME 'area superiore a 1ha'
>>>>>> EXPRESSION ( ([AREA] >= 1000000) )
>>>>>> GROUP 'delimitazione zona di vincolo'
>>>>>> MAXSCALEDENOM 4000100
>>>>>> MINSCALEDENOM 50100
>>>>>> STYLE
>>>>>> COLOR "#F2BAFE80"
>>>>>> OUTLINECOLOR "#F2BAFE"
>>>>>> ANTIALIAS false
>>>>>> END
>>>>>> END
>>>>>> CLASS
>>>>>> NAME 'area inferiore a 1ha'
>>>>>> EXPRESSION ( ([AREA] < 1000000) )
>>>>>> MINSCALEDENOM 50100
>>>>>> STYLE
>>>>>> GEOMTRANSFORM 'start'
>>>>>> SYMBOL 'circlefill'
>>>>>> SIZE 4
>>>>>> COLOR "#F2BAFEFF"
>>>>>> ANTIALIAS false
>>>>>> END
>>>>>> END
>>>>>> Unfortunately the getlegendgraphis don't recognize this symbol
>>>>>> definition and seem to render always using a polygon style (because
>>>>>> the layer is originally a polygon).
>>>>>> This is what return the GetLegendGraphics.
>>>>>> Am I wrong something in the class definitions ?
>>>>>> Many thx,
>>>>>> Andrea Peri
>>>>>> qwerty àèìòù
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> Andrea Peri
>>>> qwerty àèìòù
>> Andrea Peri
>> qwerty àèìòù
Andrea Peri
qwerty àèìòù
