[mapserver-users] GetLegendGraphics don't return correctly the point symbol
Andrea Peri
aperi2007 at gmail.com
Tue Jan 8 04:51:18 PST 2013
I try the
geomtransform centroid
Unfortunately still the GetLegendGraphics return the
OOOO
OOOO
OOOO
This is the call sample:
http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmstematici&service=wms&request=GetLegendGraphic&version=1.3.0&format=image/png&SLD_VERSION=1.1.0&layer=rt_tematici.idarch_a_1.rt&scale=60000
2013/1/8 Andrea Peri <aperi2007 at gmail.com>:
> oh oh. :)
> I don't know it was existant. It is not in the documentation. :)
> I try it instantly.
> 2013/1/8 thomas bonfort <thomas.bonfort at gmail.com>:
>> then you need geomtransform centroid, no?
>> On 8 January 2013 13:33, Andrea Peri <aperi2007 at gmail.com> wrote:
>>> Actually it is returning something like this:
>>> OOOOOOO
>>> OOOOOOO
>>> OOOOOOO
>>> OOOOOOO
>>> These seem a polygon filled with many circles internally
>>> Instead I would like to obtain something like this:
>>> O
>>>> what are you trying to obtain ?
>>>> On 8 January 2013 13:16, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>>> Hi,
>>>>> many thx for response.
>>>>>> Do you have a SIZEUNIT or SYMBOLSCALEDENOM set on your layer ?
>>>>> No.
>>>>>> Try increasing/setting your CLASS->STYLE->SIZEs, and remove the GEOMTRANSFORM
>>>>> I try to removing the geomtransform, but it do disappeared all symbol
>>>>> (ie polygons lesser then defined area).
>>>>> But I see something of good try-ing to increase the size and also
>>>>> adding a lesser than default outline.
>>>>> ie:
>>>>> size 6
>>>>> with 0.1
>>>>> and leaving the GeomTransform 'start'
>>>>> It is surely better, but still it seem a polygon filled with many circles.
>>>>> Instead my rendering is 1 only point for an entire polygon.
>>>>> This seem not clearly understandable from the returned legend.
>>>>> This is the result:
>>>>> Many thx for hints,
>>>>> Andrea.
>>>>>> thomas
>>>>>> On 8 January 2013 12:18, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>>>>> Hi,
>>>>>>> I have a polygon layer that at some scales try to render with a symbol.
>>>>>>> To do this I define a specific symbol style:
>>>>>>> SYMBOL
>>>>>>> NAME "circlefill"
>>>>>>> TYPE ellipse
>>>>>>> POINTS
>>>>>>> 1 1
>>>>>>> END
>>>>>>> FILLED true
>>>>>>> ANCHORPOINT 0.5 0.5
>>>>>>> END
>>>>>>> And use this in the class definition as here where I put two class one
>>>>>>> with a polygon rendering (when area bigger) and a second class with
>>>>>>> point rendering when area is lower:
>>>>>>> CLASS
>>>>>>> NAME 'area superiore a 1ha'
>>>>>>> EXPRESSION ( ([AREA] >= 1000000) )
>>>>>>> GROUP 'delimitazione zona di vincolo'
>>>>>>> MAXSCALEDENOM 4000100
>>>>>>> MINSCALEDENOM 50100
>>>>>>> STYLE
>>>>>>> COLOR "#F2BAFE80"
>>>>>>> OUTLINECOLOR "#F2BAFE"
>>>>>>> ANTIALIAS false
>>>>>>> END
>>>>>>> END
>>>>>>> CLASS
>>>>>>> NAME 'area inferiore a 1ha'
>>>>>>> EXPRESSION ( ([AREA] < 1000000) )
>>>>>>> MINSCALEDENOM 50100
>>>>>>> STYLE
>>>>>>> GEOMTRANSFORM 'start'
>>>>>>> SYMBOL 'circlefill'
>>>>>>> SIZE 4
>>>>>>> COLOR "#F2BAFEFF"
>>>>>>> ANTIALIAS false
>>>>>>> END
>>>>>>> END
>>>>>>> Unfortunately the getlegendgraphis don't recognize this symbol
>>>>>>> definition and seem to render always using a polygon style (because
>>>>>>> the layer is originally a polygon).
>>>>>>> This is what return the GetLegendGraphics.
>>>>>>> Am I wrong something in the class definitions ?
>>>>>>> Many thx,
>>>>>>> Andrea Peri
>>>>>>> qwerty àèìòù
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>> Andrea Peri
>>>>> qwerty àèìòù
>>> Andrea Peri
>>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
