[mapserver-users] RE RE runtime-substitution on GetFeatureInfo request
Andrea Peri
aperi2007 at gmail.com
Tue Jan 22 11:54:05 PST 2013
really many thx for help.
I don't notice the mandatory of validation block.
Now it work very well.
Regards,
Andrea Peri
2013/1/22 <Steve.Toutant at inspq.qc.ca>
> http://mapserver.org/cgi/runsub.html#validation
> Because runtime substitution affects potentially sensitive areas of your
> mapfile such as database columns and filenames, it is mandatory that you
> use pattern validation (since version 6.0)
> Whatever you are trying to do it won't work until you have a validation
> block
> *Andrea Peri <aperi2007 at gmail.com>@lists.osgeo.org*
> Envoyé par : mapserver-users-bounces at lists.osgeo.org
> 2013-01-22 13:05
> A
> mapserver-users at lists.osgeo.org
> cc
> Objet
> [mapserver-users] RE runtime-substitution on GetFeatureInfo request
> Hi,
> thx for response.
> No I not define any validation block.
> I'm try to test if it work before to apply a validation block.
> I try to apply a FILTER like this:
> FILTER "VOLO_N = 3 and (FILESTAMPE like '%IDTPN%' )"
> the goal is to obtain that on a GetFeatureInfo request where the
> response without the filter will return three or four objects,
> and identifiables with id001,id002,id003 and id004, passing a
> parameter like ..&idtpn=id001
> it will return only one object.
> also I try to apply a default value like this:
> METADATA
> 'default_idtpn' '%'
> to avoid that when I do noone idtpm parameter it will return an empty
> recordset.
> Thx
> Andrea.
> >What kind of trouble exactly?
> >Do you have a Validation block in your layer definition?
> >>2013-01-21 19:26
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130122/b8f027f9/attachment.html>
