[mapserver-users] I've been accused of not using things the way they were intended, but . . . can a getcapabilities request be run through the MapServer TEMPLATE for output?
Brent Fraser
bfraser at geoanalytic.com
Mon Jan 28 09:20:10 PST 2013
Bob,
I'm not sure I understand what you are trying to do (on the mapserver
side or the Autocad side!). Do you want mapserver to return a list of
layers (when sent an OGC GetCapabilities or equivalent non-standard
request) in a format of your choosing, similar to the way
template-driven output
(http://mapserver.org/output/template_output.html) returns feature info
in a custom format ?
Best Regards,
Brent Fraser
On 1/28/2013 8:02 AM, Basques, Bob (CI-StPaul) wrote:
> All,
> So, I was thinking about adding support for Raster pulling from
> AutoCAD work sessions directly. We've had this capability in place
> for a number of years using MapServer calls to each layer
> individually. I'm researching the idea of rebuilding the importing
> routines but with the added functionality of reading a getcapabilities
> call to flesh out the listing of the available layers in the server.
> Yes I know there is a FDO provider in AutoCAD, but that is only
> available in Map and Civil, not regular AutoCAD (or ARCH, still??)
> Versions which we also support.
> First thought was to build a XML parser as a separate web service,
> that would make the call(s) to mapserver. This would output the data
> in a AutoCAD readable form such as AutoLISP. Another thought was to
> read our GeoMoose MapBook, an XML file, for listing out the available
> layers behind MapServer, this has the advantage of using our existing
> tools and methods for access the data and it would be completely
> automated with the GeoMoose MapBook becoming the master data catalog.
> Whatever comes of this will also be eventually morphed into a Feature
> importer (WFS, etc) as well, which we also already have in place, but
> in a manner that could be improved.
> So, back to the question, can a XML return from MapServer be passed
> through a TEMPLATE to change the output?
> Thanks
> Bobb
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130128/83c8882c/attachment.html>
