[mapserver-users] HTML response to GetFeature request
Luís de Sousa
luis.a.de.sousa at gmail.com
Mon Jul 1 02:31:44 PDT 2013
Hi Jukka,
I also do get correct results with Poster, but not with API Kitchen. This
is really frustrating, but at least the service seems to running as it
should.
Thank you,
Luís
On 28 June 2013 15:17, Rahkonen Jukka <jukka.rahkonen at mmmtike.fi> wrote:
> Sorry, nothing wrong with the typename and using
> "feature:RO_buildings_gml". Namespace “feature” is described later in the
> request and I do get correct results with Poster if I have
> typeName="feature:RO_buildings_gml" srsName="EPSG:28992" xmlns:feature="
> http://mapserver.gis.umn.edu/mapserver">
> -Jukka-
> Rahkonen Jukka wrote:
> > Hi,
> > I made a trial with Firefox Poster plugin and I get correct results back
> after
> > correcting the typename. I do not know what is wrong with API Kitchen
> and your
> > other trials.
> > <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> > version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
> > http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> > <wfs:Query typeName="RO_buildings_gml" srsName="EPSG:28992"
> > xmlns:feature="http://mapserver.gis.umn.edu/mapserver"></wfs:Query>
> > </wfs:GetFeature>
> > Kosmo Desktop 3.0 beta
> > http://www.opengis.es/index.php?option=com_docman&Itemid=42?lang=en
> > reads data with http POST from your site basically fine. You have some
> data
> > errors, though, and Kosmo says that there is dublicate fid around fid
> .168 .
> > -Jukka Rahkonen-
> > > -----Alkuperäinen viesti-----
> > > Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> > > [mailto:mapserver-users- bounces at lists.osgeo.org] Puolesta Luís de
> > > Sousa
> > > Lähetetty: 28. kesäkuuta 2013 15:30
> > > Vastaanottaja: mapserver-users at lists.osgeo.org
> > > Aihe: Re: [mapserver-users] HTML response to GetFeature request
> > > Hi Michael thank you for the reply, my comments go below.
> > > Michael Schulz-6 wrote
> > > > Hi Luis,
> > > > for WFS enabling layers you should add some more metadata, wfs_srs
> > > > and gml_featureid.
> > > I've added these to the LAYER block, but the response is the same (see
> > > the definition below). I have had both "ows_enable_request" and
> > > "gml_include_items" "all" in the main file section all along.
> > > > I'm also not sure about the projection stuff. Is there a reason for
> > > > not using the espg code?
> > > The in line projection definition is supposed to speed up rendition.
> > > > Try adding some debug logging.
> > > Here's what I'm getting in the MapServer log:
> > > [Fri Jun 28 14:17:09 2013].620005 CGI Request 1 on process 9189 [Fri
> > > Jun 28
> > > 14:17:09 2013].621842 msDrawMap(): rendering using outputformat named
> > > GTiff-RGB (GDAL/GTiff).
> > > [Fri Jun 28 14:17:09 2013].621861 msDrawMap(): WMS/WFS set-up and
> > > query, 0.000s [Fri Jun 28 14:17:09 2013].621900 msDrawMap(): Drawing
> > > Label Cache, 0.000s [Fri Jun 28 14:17:09 2013].621908 msDrawMap()
> > > total time: 0.002s [Fri Jun 28 14:17:09 2013].657425
> > > msSaveImage(/var/www/MapFiles/map_images/TUDOR_RO_test-
> > > environment13724218299189.tif)
> > > total time: 0.036s
> > > [Fri Jun 28 14:17:09 2013].658291 mapserv request processing time
> > > (msLoadMap not incl.): 0.038s [Fri Jun 28 14:17:09 2013].658311
> > msFreeMap():
> > > freeing map at 0x10c1940.
> > > > Another thing to check: your requesting
> > > > typeName="feature:BuildingsWFS" but from the mapfile I'd say the
> > > > typename shoud be "RO_buildings_gml".
> > > Yes, it seems the first POST body I posted is wrong, but I'm using the
> > > correct layer name testing. You can try it here:
> > > http://apikitchen.com/#bXd2s
> > > Once again, note that with a GET request everything works as it should:
> > > http://services.iguess.tudor.lu/cgi-
> > bin/mapserv?map=/var/www/MapFiles/RO_localOWS_test.map&SERVICE=WFS
> > &VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=RO_buildings_gml&MAXF
> > > EATURES=10
> > > Thank you once more,
> > > Luís
> > > #########################################3
> > > LAYER
> > > NAME "RO_buildings_gml"
> > > TYPE POLYGON
> > > CONNECTIONTYPE OGR
> > > CONNECTION "/var/www/pywps/sampleData/BuildingsFull.gml"
> > > STATUS ON
> > > DUMP TRUE
> > > TEMPLATE "templateRO_building_footprints.html"
> > > PROJECTION
> > > "+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
> > > +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
> > > +towgs84=565.237,50.0087,465.658,-0.406857,0.350733,-1.87035,4.0812
> > > ++units=m no_defs"
> > > END
> > > METADATA
> > > "ows_title" "Building footprints (GML)"
> > > "ows_abstract" "Data set of building footprints in Rotterdam city
> > > area for the slider demo"
> > > "wfs_srs" "EPSG:28992"
> > > "gml_featureid" "GML_ID"
> > > "ows_enable_request" "*"
> > > END
> > > CLASS
> > > NAME "Building_footprints (GML)"
> > > OUTLINECOLOR 255 0 0
> > > END
> > > END
> > > View this message in context:
> > > http://osgeo-org.1560.x6.nabble.com/HTML-
> > > response-to-GetFeature-request-tp5062355p5062817.html
> > > Sent from the Mapserver - User mailing list archive at Nabble.com.
> > > _______________________________________________
> > > mapserver-users mailing list
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130701/869a0a60/attachment.html>
