[mapserver-users] Dimension default doesn't work and documentation is patchy
thomas bonfort
thomas.bonfort at gmail.com
Thu Jul 4 01:43:14 PDT 2013
semska,
As I have already replied to you on the issue tracker, WMS dimensions were
added in 6.2.0, i.e. quite a few versions after your 5.6.0
On 4 July 2013 10:34, semska <semska at gmail.com> wrote:
> Hi Stefan,
> I am also trying to use custom dimension in a WMS layer, but I am not able
> to make it work. I am using ms4w and mapserver version 5.6. I get the time
> dimension to work, but none of my custom variants has worked so far. My
> sample WMS file:
> METADATA
> "ows_title" "skipshaler_dim"
> "ows_srs" "EPSG:4326 EPSG:3575"
> "wms_enable_request" "*"
> "wms_dimensionlist" "SHIPTYPE"
> "wms_SHIPTYPE_item" "skipskategori"
> "wms_SHIPTYPE_extent" "1/13/1"
> "wms_SHIPTYPE_units" "none"
> "wms_SHIPTYPE_default" "2"
> "default_SHIPTYPE" "2"
> END
> I cannot see this dimension in getCapabilites and the filter is not applied
> when making map request.
> Any idees to why this is not working?
> Best regards,
> Richard
> http://osgeo-org.1560.x6.nabble.com/Dimension-default-doesn-t-work-and-documentation-is-patchy-tp5019828p5064003.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130704/2321ee61/attachment.html>
