[mapserver-users] R: Re: dynamic sql to mapserver
Daniel Morissette
dmorissette at mapgears.com
Wed Jul 10 06:22:53 PDT 2013
Run-time substitutions work with both traditional CGI and WMS requests.
The key is to make sure you have the VALIDATION patterns set properly.
Daniel
On 13-07-10 9:20 AM, Michele De Santis wrote:
> Thanks,
> but does it work only with a standard cgi request? Does it means that i
> can't do runtime substitution with a WMS request?
> michele
> ----Messaggio originale----
> Da: dmorissette at mapgears.com
> Data: 10-lug-2013 14.09
> A: <mapserver-users at lists.osgeo.org>
> Ogg: Re: [mapserver-users] dynamic sql to mapserver
> On 13-07-10 5:25 AM, Michele De Santis wrote:
> > Hi to everyone,
> > in my webgis application I'm using OpenLayers to request WMS layers to
> > MapServer 6.2.1. Is it possible to send dynamic sql to mapserver using
> > function of PostGIS (for example ST_Distance)?
> > /select * from table
> where//st_distance(the_geom,GeomFromText('Point(1 0)',4326)) <6) as myquery;
> > /What I would like to be able to do is pass user defined variables
> e.g. latitude, longitude and distance.
> %variable% run-time substitution should do what you need, see:
> http://mapserver.org/cgi/runsub.html
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
Daniel Morissette
