[mapserver-users] Error on mapserver
ciskazza at tiscali.it
Wed Jul 10 07:15:19 PDT 2013
Hi !!
I have a problem with my mapserver
I have installed the
mapserver 6.2.1 and have make the test with result : "No query
information to decode. QUERY_STRING is set, but empty"..so my
installation is ok
I have installed also the MapScript and have create
2 file as to verify : test.php and province.map , but I have a serious
problem .
PS: The library 'php_mapscript.so' is installed in the
directory where there are the library of php
the file test.php :
php
// dl('php_mapscript.so');
$map_path="/var/www/html/TCR/map/";
$map = ms_newMapObj($map_path."province.map");
// Let's see all the
records:
$map->setextent(-1,2823039,56501,6022882);
$image=$map-
>draw();
$image_url=$image->saveWebImage();
<HTML>
<HEAD>
<TITLE>Example 1: Displaying a map</TITLE>
</HEAD>
<BODY>
<IMG SRC=<?php echo $image_url; ?> >
</BODY>
</HTML>
The file
province.map :
NAME "Europe in purple"
SIZE 400 400
STATUS ON
EXTENT
277679.0098 4067180.7913 1318975.2968 5226899.0089
UNITS METERS
SHAPEPATH "/var/www/html/TCR/map/italia/"
IMAGETYPE PNG
INTERLACE FALSE
WEB
IMAGEPATH "/usr/local/wwwssl/TCR/map/img/"
IMAGEURL
"/TCR/map/img/"
END
LAYER
NAME "1"
TYPE POLYGON
STATUS ON
DATA "prov2010_s"
CLASSITEM 'COD_PRO'
CLASS
EXPRESSION "1"
STYLE
COLOR 255 255 255
OUTLINECOLOR 50 50 50
SYMBOL 0
END
END
END
LAYER
NAME "2"
TYPE POLYGON
STATUS ON
DATA "prov2010_s"
CLASSITEM 'COD_PRO'
CLASS
EXPRESSION "2"
STYLE
COLOR 255 255 255
SYMBOL 0
END
END
END
On the bowser I make to
call the file test.php ,but i received an error ...so i make see the
file log of the server .
In the file "error_log" there is :
PHP
Warning: ms_newMapObj(): [MapServer Error]: msLoadMap(): First token
must be MAP, this doesn't look like a mapfile.\n in
/var/www/html/TCR/map/test.php
PHP Fatal error: Uncaught exception
'MapScriptException' with message 'Failed to open map file
"/var/www/html/TCR/map/province.map", or map file error.' in
/var/www/html/TCR/map/test.php:8\nStack trace:\n#0
/var/www/html/TCR/map/test.php(8): ms_newMapObj('/var/www/html/T...')
\n#1 {main}\n thrown in /var/www/html/TCR/map/test.php on line 8
Why
Invita i tuoi amici e Tiscali ti premia! Il consiglio di un amico vale più di uno spot in TV. Per ogni nuovo abbonato 30 € di premio per te e per lui! Un amico al mese e parli e navighi sempre gratis: http://freelosophy.tiscali.it/
