[mapserver-users] MapServer performance question - slow on different machine
Mark Volz
MarkVolz at co.lyon.mn.us
Wed Jul 24 08:59:59 PDT 2013
Hello,
I had an old MapServer application running on a production machine. It used IIS and it ran fast. I upgraded the application on a development machine. I switched over to Apache (for MapCache) and the new application ran fast on my development machine. We moved the new application onto the production machine. It does not run fast.
I am trying to figure out why MapServer 5 would run fast under IIS, while MapServer 6 under Apache runs slow. There are a couple possibilities, if anyone could confirm the following as a problem, or has a solution please let me know
* The machine is now running both IIS on port 80, and Apache on port 8080.
o I have a similar setup on another server, and this does not seem to be a problem at all.
* The machine is using a 6.8 out of the available 8GB of RAM
o I think we need more RAM on the system, however I am curious as to why the MapServer 5 application ran fast, while MapServer 6 is slow. Could IIS just behave better than Apache under low RAM situations?
o That being said both Apache and MapServer take a minimal amount of RAM
Machine Specs:
Developer Machine
* MapServer 6.1 MS4W 3 Beta running Apache with MapCache
* 4 Core, 16 GB RAM
Production Machine
* MapServer 6.1 MS4W 3 Beta running Apache with MapCache on port 8080
* IIS is also on the machine on port 80
* 8 Core, 8 GB RAM
* At one time IIS was running MapServer 5 at a reasonable speed
Thanks for any help or ideas
Mark Volz, GISP
GIS Specialist
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130724/b3b7012b/attachment.html>
