[mapserver-users] MapServer performance question - slow on different machine
Umberto Nicoletti
umberto.nicoletti at gmail.com
Thu Jul 25 23:55:37 PDT 2013
the only difference seems to be the presence of MapCache on the slower
system. Could you try removing it ?
hth,
Umberto
On Thursday, July 25, 2013, andy wrote:
> On 7/25/2013 1:56 PM, andy wrote:
>> On 7/24/2013 10:59 AM, Mark Volz wrote:
>>> Hello,
>>> ·The machine is using a 6.8 out of the available 8GB of RAM
>>> oI think we need more RAM on the system, however I am curious as to why
>>> the MapServer 5 application ran fast, while MapServer 6 is slow. Could
>>> IIS just behave better than Apache under low RAM situations?
>>> oThat being said both Apache and MapServer take a minimal amount of RAM
> I'm coming from the linux world, but I have to assume windows would do the
> same: your os should be caching the snot out of your disk. Hopefully that
> 6.8 gig of usage is for disk cache. Any way to tell if that's the case?
> You want all of your ram used as disk cache.
> Is there a way to see how much cpu vs disk is being used? If your cpu
> usage is high and disk io is low, then you have a huge cache and you don't
> need more ram.
> If your cpu is low and your disk io is high, then you have a tiny cache,
> and you could use more ram.
> -Andy
> ______________________________**_________________
> mapserver-users at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130726/3e477b97/attachment.html>
