[mapserver-users] Transform from black/white to white/gray
Andrea Peri
aperi2007 at gmail.com
Sat Jul 27 05:34:53 PDT 2013
I resolve using another solution:
I define 2 class. In every class I filter the pixel with expression and
render white as grey and black as white.
Regards,
Andrea.
2013/7/26 Andrea Peri <aperi2007 at gmail.com>
> Hi,
> I have a raster set of rasters tiff4 black/white.
> Usually I server them using mapserver wms in back/white.
> But now I need to server them also in white/gray to allow overlaps them on
> other rasters.
> So I need to change the black in white and the white in gray.
> I try to use the
> processing LUT command to obtain this transformation.
> I try with this command set:
> PROCESSING "SCALE_1=1,255"
> PROCESSING "BANDS=1"
> PROCESSING "LUT=0:64,1:0"
> But it don't seem work. Seem instead that all the raster become all white.
> I guess the problem is that the original raster is tiff4 (2 color only).
> Is capable the processing command to transform it in a single band with
> 255 levels ?
> Thx,
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130727/7c13fff9/attachment.html>
