[mapserver-users] No Postgresql mapserver images
Michael McInnis
mmcinnis59 at msn.com
Fri Jul 26 16:01:47 PDT 2013
Problem: Although I can use my mapserver install to draw
shapefile maps I can’t draw maps from my postgres source. I can also display
the postgres points in QGIS so I’m not sure what the problem is in mapserver.
Ideas? Thanks in Advance !
http://mapserver0/cgi-bin/mapserv?map=/media/D_Drive/www/gis/postgresMap.map&layer=airports&mode=map
msDrawMap(): Image handling error. Failed to draw layer
named 'airports'. msPostGISLayerWhichShapes(): Query error. Error (ERROR:
function geomfromtext(unknown, integer) does not exist LINE 1: ...,'hex') as
geom,"oid" from airports where geom && GeomFromTe... ^ HINT:
No function matches the given name and argument types. You might need to add
explicit type casts. ) executing query: select encode(ST_AsBinary(ST_Force_2D("geom"),'NDR'),'hex')
as geom,"oid" from airports where geom &&
GeomFromText('POLYGON((-180.180360721443 -90,-180.180360721443
90,180.180360721443 90,180.180360721443 -90,-180.180360721443
-90))',find_srid('','airports','geom'))
postgresMap.map file:
MAP
NAME airports EXTENT -180 -90 180 90
SIZE 1000 500
#SHAPEPATH "./data"
SYMBOL
NAME "circle-filled"
TYPE ELLIPSE
FILLED TRUE
POINTS 1 1 END
END
LAYER
CONNECTIONTYPE POSTGIS
NAME airports
CONNECTION "host=localhost
dbname=Airports user=xxxx password=xxxx port=5432"
PROCESSING
"CLOSE_CONNECTION=DEFER"
DATA "geom From airports"
#DATA "geom From (select icao,
geom From airports) as subquery using unique icao using srid=4326"
STATUS ON
TYPE POINT
CLASS
NAME "airportsClass"
SYMBOL 'circle-filled'
SIZE 2
COLOR 255 22 22
END
END # Class
END # Layer
END #
Map File
Michael McInnis
6033 44th Ave. N.E.
Seattle, WA 98115
206 517-4701
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130726/50783df1/attachment-0001.html>
