[mapserver-users] Trouble with MS 6.2.1 and native vector tileindex
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Tue Jun 4 05:42:08 PDT 2013
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> bounces at lists.osgeo.org] Puolesta Jeff McKenna
> Lähetetty: 4. kesäkuuta 2013 15:09
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Trouble with MS 6.2.1 and native vector tileindex
> On 2013-06-04 8:56 AM, Rahkonen Jukka wrote:
> > Hi,
> > I have been using for some years a biggish shapefile directory through
> > shapefile tileindex. The layer is in production with Mapserver 6.0
> > (MS4W) and the layer is defined like this
> > LAYER
> > NAME "bunch_of_shapes"
> > TYPE POLYGON
> > #CONNECTIONTYPE OGR #don't use, it breaks classification and
> GetFeatureInfo
> > #left here as a reminder on 2010-10-20 JRA
> > TILEINDEX "/data/tindex/polygon_idx.shp,0"
> What happens if you remove the layername ",0" from the TILEINDEX ?
Sorry, I did not mention that I tried by having
TILEINDEX "/data/tindex/polygon_idx.shp".
The LOCATION field in the index file polygon_idx.shp created by ogrtindex contains entries like /full/path/SHAPE.SHP,0
I made also a try by shortening them into /full/path/SHAPE.SHP
The shortened index file behaved in the same way and was OK with OGR connection but the native shp driver did not find the target shapefiles.
-Jukka-
