[mapserver-users] Trouble with MS 6.2.1 and native vector tileindex
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jun 4 05:50:51 PDT 2013
What happens if you use tile4ms to generate the tileindex? (these are
steps I usually go through when debugging)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2013-06-04 9:42 AM, Rahkonen Jukka wrote:
>> -----Alkuperäinen viesti-----
>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
>> bounces at lists.osgeo.org] Puolesta Jeff McKenna
>> Lähetetty: 4. kesäkuuta 2013 15:09
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: Re: [mapserver-users] Trouble with MS 6.2.1 and native vector tileindex
>> On 2013-06-04 8:56 AM, Rahkonen Jukka wrote:
>>> Hi,
>>> I have been using for some years a biggish shapefile directory through
>>> shapefile tileindex. The layer is in production with Mapserver 6.0
>>> (MS4W) and the layer is defined like this
>>> LAYER
>>> NAME "bunch_of_shapes"
>>> TYPE POLYGON
>>> #CONNECTIONTYPE OGR #don't use, it breaks classification and
>> GetFeatureInfo
>>> #left here as a reminder on 2010-10-20 JRA
>>> TILEINDEX "/data/tindex/polygon_idx.shp,0"
>> What happens if you remove the layername ",0" from the TILEINDEX ?
> Sorry, I did not mention that I tried by having
> TILEINDEX "/data/tindex/polygon_idx.shp".
> The LOCATION field in the index file polygon_idx.shp created by ogrtindex contains entries like /full/path/SHAPE.SHP,0
> I made also a try by shortening them into /full/path/SHAPE.SHP
> The shortened index file behaved in the same way and was OK with OGR connection but the native shp driver did not find the target shapefiles.
> -Jukka-
