[mapserver-users] Mapcache tileset only shows sporadically in KML / Google Earth
John D. Evans
john.evans at gst.com
Sat Jun 8 12:41:43 PDT 2013
Thomas Bonfort wrote on 06/06/2013:
> As for the root issue, are your tilesets fully preseeded or are they
> populated on demand? KML superoverlays are organized in a tree, i.e.
> to access a tile at zoom level N you first need to access all parent
> tiles from level 0 to N-1; on an unseeded tileset with a slow wms
> backend this might be a very long wait. Also please check the apache
> error log for any mapcache related messages.
Thanks for the input! Sorry for the delayed reply. My tiles had been
populated on demand but I finally found, installed, and ran
"mapcache_seed". It's now been running for 10+ hours now (*) but I still
get the same effect in Google Earth. (A very low-resolution view
displays when I'm zoomed out very far, but disappears as soon as I try
to zoom in.) Does the seeding have to be completely finished before
Google Earth can see beyond the top-level KML tiles?
Thanks again.
- John E.
(*) I'm running this on a fairly puny virtual machine (2 cores); I guess
I should try seeding with 8 or 10 threads on an 8-core machine. I will
also try limiting my zoom levels (I suspect I'm seeding 0-17 by default)
and my spatial extent (I'm probably doing the whole globe by default --
lots of blank tiles :-).
> On 6 June 2013 05:19, John D. Evans <john.evans at gst.com
> <mailto:john.evans at gst.com>> wrote:
> Hello,
> Not sure my earlier query made it to the list.
> I'm using MapCache to serve for some satellite image products. It
> sort of works: the tms and wmts browsers at /mapcache/demo show
> full coverage of my data area, and let users zoom in to see full
> resolution image mosaics. But the KML superoverlay (my reason for
> using MapCache) only displays in Google Earth when I'm zoomed very
> far out (so that the entire globe is not much bigger than a golf
> ball on my screen). If I zoom in, the image usually disappears;
> though sometimes when zoomed in I do see [only] the right (east)
> half of my tileset, at a very low resolution.
> Do you see anything wrong with my mapcache.xml (below)?
> Is there anything else I should be checking?
> (I'm using a simple disk cache in /tmp, with mod_mapcache from the
> Ubuntu libmapcache 1.0.0-3 package; Mapserver 6.2.1 is on the same
> machine, running in 64-bit Ubuntu 12.04. Mapserver works fine, and
> reports no errors [I think]. My client is Google Earth 7.)
> Thanks for taking a look,
> - John D. Evans
> GST, Inc / Greenbelt, MD
> Below is my mapcache.xml file (actually an excerpt of it:
> the real one has more tilesets and sources).
> <mapcache>
> <metadata>
> <title>my mapcache service</title>
> <abstract>woot! this is a service abstract!</abstract>
> </metadata>
> <cache name="disk" type="disk">
> <base>/tmp</base>
> <symlink_blank/>
> </cache>
> <format name="PNG_BEST" type ="PNG">
> <compression>best</compression>
> </format>
> <format name="PNG_FAST" type ="PNG">
> <compression>fast</compression>
> </format>
> <source name="CSPP_CloudPhase" type="wms">
> <http>
> <url>http://localhost/cgi-bin/mapserv?</url>
> </http>
> <getmap>
> <params>
> <FORMAT>image/png</FORMAT>
> <LAYERS>iicmocp_daily</LAYERS>
> <MAP>/raid/maps/viirs.map</MAP>
> </params>
> </getmap>
> </source>
> <tileset name="CSPP_Cloud_Phase_EDR">
> <metadata>
> <title>VIIRS Cloud Phase from NASA GSFC DRL</title>
> <abstract>Detailed description goes here</abstract>
> </metadata>
> <source>CSPP_CloudPhase</source>
> <cache>disk</cache>
> <format>PNG</format>
> <grid>WGS84</grid>
> <metatile>2 2</metatile>
> <expires>3600 <tel:3600></expires>
> <auto_expire>3600 <tel:3600></auto_expire>
> <!-- <metabuffer>10</metabuffer> -->
> </tileset>
> <default_format>PNG_FAST</default_format>
> <service type="wms" enabled="true">
> <full_wms>assemble</full_wms>
> <resample_mode>bilinear</resample_mode>
> <format>PNG_FAST</format>
> <!-- <maxsize>4096</maxsize> -->
> </service>
> <service type="wmts" enabled="true"/>
> <service type="tms" enabled="true"/>
> <service type="kml" enabled="true"/>
> <service type="gmaps" enabled="true"/>
> <service type="ve" enabled="true"/>
> <service type="demo" enabled="true"/>
> <lock_dir>/tmp</lock_dir>
> <errors>report</errors>
> <threaded_fetching>true</threaded_fetching>
> </mapcache>
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> NOTE: This message was trained as non-spam. If this is wrong, please
> correct the training as soon as possible.
> Spam <https://filter.gst.com/canit/b.php?i=01JIUgvAE&m=e50f357136f6&c=s>
> Not spam
> <https://filter.gst.com/canit/b.php?i=01JIUgvAE&m=e50f357136f6&c=n>
> Forget previous vote
> <https://filter.gst.com/canit/b.php?i=01JIUgvAE&m=e50f357136f6&c=f>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130608/bd297474/attachment.html>
