[mapserver-users] HTML response to GetFeature request
Luís de Sousa
luis.a.de.sousa at gmail.com
Fri Jun 28 05:29:38 PDT 2013
Hi Michael thank you for the reply, my comments go below.
Michael Schulz-6 wrote
> Hi Luis,
> for WFS enabling layers you should add some more metadata, wfs_srs and
> gml_featureid.
I've added these to the LAYER block, but the response is the same (see the
definition below). I have had both "ows_enable_request" and
"gml_include_items" "all" in the main file section all along.
> I'm also not sure about the projection stuff. Is there a
> reason for not using the espg code?
The in line projection definition is supposed to speed up rendition.
> Try adding some debug logging.
Here's what I'm getting in the MapServer log:
[Fri Jun 28 14:17:09 2013].620005 CGI Request 1 on process 9189
[Fri Jun 28 14:17:09 2013].621842 msDrawMap(): rendering using outputformat
named GTiff-RGB (GDAL/GTiff).
[Fri Jun 28 14:17:09 2013].621861 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Fri Jun 28 14:17:09 2013].621900 msDrawMap(): Drawing Label Cache, 0.000s
[Fri Jun 28 14:17:09 2013].621908 msDrawMap() total time: 0.002s
[Fri Jun 28 14:17:09 2013].657425
msSaveImage(/var/www/MapFiles/map_images/TUDOR_RO_test-environment13724218299189.tif)
total time: 0.036s
[Fri Jun 28 14:17:09 2013].658291 mapserv request processing time (msLoadMap
not incl.): 0.038s
[Fri Jun 28 14:17:09 2013].658311 msFreeMap(): freeing map at 0x10c1940.
> Another thing to check: your requesting
> typeName="feature:BuildingsWFS" but from the mapfile I'd say the typename
> shoud be "RO_buildings_gml".
Yes, it seems the first POST body I posted is wrong, but I'm using the
correct layer name testing. You can try it here:
http://apikitchen.com/#bXd2s
Once again, note that with a GET request everything works as it should:
http://services.iguess.tudor.lu/cgi-bin/mapserv?map=/var/www/MapFiles/RO_localOWS_test.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=RO_buildings_gml&MAXFEATURES=10
Thank you once more,
Luís
#########################################3
LAYER
NAME "RO_buildings_gml"
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "/var/www/pywps/sampleData/BuildingsFull.gml"
STATUS ON
DUMP TRUE
TEMPLATE "templateRO_building_footprints.html"
PROJECTION
"+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
+towgs84=565.237,50.0087,465.658,-0.406857,0.350733,-1.87035,4.0812 +units=m
+no_defs"
END
METADATA
"ows_title" "Building footprints (GML)"
"ows_abstract" "Data set of building footprints in Rotterdam city area
for the slider demo"
"wfs_srs" "EPSG:28992"
"gml_featureid" "GML_ID"
"ows_enable_request" "*"
END
CLASS
NAME "Building_footprints (GML)"
OUTLINECOLOR 255 0 0
END
END
View this message in context: http://osgeo-org.1560.x6.nabble.com/HTML-response-to-GetFeature-request-tp5062355p5062817.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
