[mapserver-users] HTML response to GetFeature request
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Fri Jun 28 06:17:34 PDT 2013
Sorry, nothing wrong with the typename and using "feature:RO_buildings_gml". Namespace “feature” is described later in the request and I do get correct results with Poster if I have
typeName="feature:RO_buildings_gml" srsName="EPSG:28992" xmlns:feature="http://mapserver.gis.umn.edu/mapserver">
-Jukka-
Rahkonen Jukka wrote:
> Hi,
> I made a trial with Firefox Poster plugin and I get correct results back after
> correcting the typename. I do not know what is wrong with API Kitchen and your
> other trials.
> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <wfs:Query typeName="RO_buildings_gml" srsName="EPSG:28992"
> xmlns:feature="http://mapserver.gis.umn.edu/mapserver"></wfs:Query>
> </wfs:GetFeature>
> Kosmo Desktop 3.0 beta
> http://www.opengis.es/index.php?option=com_docman&Itemid=42?lang=en
> reads data with http POST from your site basically fine. You have some data
> errors, though, and Kosmo says that there is dublicate fid around fid .168 .
> -Jukka Rahkonen-
> > -----Alkuperäinen viesti-----
> > Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users- bounces at lists.osgeo.org] Puolesta Luís de
> > Sousa
> > Lähetetty: 28. kesäkuuta 2013 15:30
> > Vastaanottaja: mapserver-users at lists.osgeo.org
> > Aihe: Re: [mapserver-users] HTML response to GetFeature request
> > Hi Michael thank you for the reply, my comments go below.
> > Michael Schulz-6 wrote
> > > Hi Luis,
> > > for WFS enabling layers you should add some more metadata, wfs_srs
> > > and gml_featureid.
> > I've added these to the LAYER block, but the response is the same (see
> > the definition below). I have had both "ows_enable_request" and
> > "gml_include_items" "all" in the main file section all along.
> > > I'm also not sure about the projection stuff. Is there a reason for
> > > not using the espg code?
> > The in line projection definition is supposed to speed up rendition.
> > > Try adding some debug logging.
> > Here's what I'm getting in the MapServer log:
> > [Fri Jun 28 14:17:09 2013].620005 CGI Request 1 on process 9189 [Fri
> > Jun 28
> > 14:17:09 2013].621842 msDrawMap(): rendering using outputformat named
> > GTiff-RGB (GDAL/GTiff).
> > [Fri Jun 28 14:17:09 2013].621861 msDrawMap(): WMS/WFS set-up and
> > query, 0.000s [Fri Jun 28 14:17:09 2013].621900 msDrawMap(): Drawing
> > Label Cache, 0.000s [Fri Jun 28 14:17:09 2013].621908 msDrawMap()
> > total time: 0.002s [Fri Jun 28 14:17:09 2013].657425
> > msSaveImage(/var/www/MapFiles/map_images/TUDOR_RO_test-
> > environment13724218299189.tif)
> > total time: 0.036s
> > [Fri Jun 28 14:17:09 2013].658291 mapserv request processing time
> > (msLoadMap not incl.): 0.038s [Fri Jun 28 14:17:09 2013].658311
> msFreeMap():
> > freeing map at 0x10c1940.
> > > Another thing to check: your requesting
> > > typeName="feature:BuildingsWFS" but from the mapfile I'd say the
> > > typename shoud be "RO_buildings_gml".
> > Yes, it seems the first POST body I posted is wrong, but I'm using the
> > correct layer name testing. You can try it here:
> > http://apikitchen.com/#bXd2s
> > Once again, note that with a GET request everything works as it should:
> > http://services.iguess.tudor.lu/cgi-
> bin/mapserv?map=/var/www/MapFiles/RO_localOWS_test.map&SERVICE=WFS
> &VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=RO_buildings_gml&MAXF
> > EATURES=10
> > Thank you once more,
> > Luís
> > #########################################3
> > LAYER
> > NAME "RO_buildings_gml"
> > TYPE POLYGON
> > CONNECTIONTYPE OGR
> > CONNECTION "/var/www/pywps/sampleData/BuildingsFull.gml"
> > STATUS ON
> > DUMP TRUE
> > TEMPLATE "templateRO_building_footprints.html"
> > PROJECTION
> > "+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
> > +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
> > +towgs84=565.237,50.0087,465.658,-0.406857,0.350733,-1.87035,4.0812
> > ++units=m no_defs"
> > END
> > METADATA
> > "ows_title" "Building footprints (GML)"
> > "ows_abstract" "Data set of building footprints in Rotterdam city
> > area for the slider demo"
> > "wfs_srs" "EPSG:28992"
> > "gml_featureid" "GML_ID"
> > "ows_enable_request" "*"
> > END
> > CLASS
> > NAME "Building_footprints (GML)"
> > OUTLINECOLOR 255 0 0
> > END
> > END
> > View this message in context:
> > http://osgeo-org.1560.x6.nabble.com/HTML-
> > response-to-GetFeature-request-tp5062355p5062817.html
> > Sent from the Mapserver - User mailing list archive at Nabble.com.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
