[mapserver-users] Σχετ: First attempt on Maserver
Stephen Woodbridge woodbri at swoodbridge.com
Mon Mar 4 11:36:06 PST 2013
Ok, my error.
You should probably NOT have the file /var/www/cgi-bin this looks very
bad. I would look at this file and see what it is doing.
less /var/www/cgi-bin
What you should have:
$ ls -ld /usr/lib/cgi-bin/
drwxr-xr-x 2 root root 4096 Mar 16  2012 /usr/lib/cgi-bin/
$ ls -l /usr/lib/cgi-bin/
total 36
-rwxr-xr-x 1 root root 34461 Mar 28  2012 mapserv
$ /usr/lib/cgi-bin/mapserv -v
MapServer version 6.2.0 OUTPUT=PNG
OUTPUT=JPEG SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV INPUT=JPEG
INPUT=SHAPEFILE
What Linux distribution are you running?
-Steve
On 3/4/2013 1:32 PM, Stefanos Anastasiou wrote:
> OK I'm pasting the results of the commands:
> file /var/www/cgi-bin    ----> /var/www/cgi-bin: Bourne-Again shell
> script, ASCII text executable, with very long lines
> ls -l /var/www/cgi-bin  ----> -rwxr-xr-x 1 root root 7542 Feb 28 20:42
> /var/www/cgi-bin
> /var/www/cgi-bin/mapserv -v     ----> MapServer version 6.2.0 OUTPUT=PNG
> INPUT=SHAPEFILE
> What is strange though is that I installed apache through the
> repositories and there is no config file, no log file... nothing... just
> a folder /var/www
> Apart from that server seems to work.. no need to restart every time...
> what is strange though is that I get a weird message when I
> start/restart/stop which is:
> * Restarting web server apache2      apache2: Could not reliably
> determine the server's fully qualified domain name, using 127.0.1.1 for
> ServerName
>   ... waiting apache2: Could not reliably determine the server's fully
> qualified domain name, using 127.0.1.1 for ServerName
> what's wrong here?
> *Απο:* Stephen Woodbridge <woodbri at swoodbridge.com>
> *Προς:* mapserver-users at lists.osgeo.org
> *Στάλθηκε:* 10:06 μ.μ. Πέμπτη, 28 Φεβρουαρίου 2013
> *Θέμα:* Re: [mapserver-users] First attempt on Maserver
> On 2/28/2013 2:14 PM, Stefanos Anastasiou wrote:
>  > Hello everyone!
>  > I'm quite new to mapserver and I'm experimenting with the 2 first
>  > examples of Kropla's book... the first one, that is supposed to produce
>  > just an image... I click on "Click me" button and the message I get is:
>  > Not Found
>  > The requested URL /cgi-bin/mapserv was not found on this server
>  > I don't get it.. according to the instructions cp mapserv
> /var/www/cgi-bin
>  > Why isn't it working?
> OK, there are a bunch of assumptions in the above:
> cp mapserv /var/www/cgi-bin
> assumes the apache or your webserver is configured to look for cgi-bin
> files in this directory
> assumes that the directory already exists. what does these report:
> ls -l /var/www/cgi-bin/mapserv
> If the above looks ok, then you probably need to look at the apache
> config. If you changed the apache config as part of your install, have
> you restarted apache:
> sudo /etc/init.d/apache2 restart
>    or
> sudo /etc/init.d/apache restart
> -Steve W
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
More information about the MapServer-users mailing list
