[mapserver-users] Σχετ: Σχετ: First attempt on Maserver
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 4 12:20:31 PST 2013
Yes you should not copy the mapserv file anymore 6.2+
You have to sudo make install to install it correctly.
So to clean this up:
sudo rm /var/www/cgi-bin
cd /path/to/mapserv/src-tree
sudo make install
sudo cp /usr/local/bin/mapserv /usr/lib/cgi-bin/mapserv
Then things should start working better.
-Steve W
On 3/4/2013 2:57 PM, Stefanos Anastasiou wrote:
> less /var/www/cgi-bin gives a very very long bash (?) that looks
> something like...
> #! /bin/bash
> # mapserv - temporary wrapper script for .libs/mapserv
> # Generated by libtool (GNU libtool) 2.4.2
> # The mapserv program cannot be directly executed until all the libtool
> # libraries that it depends on are installed.
> # This wrapper script should never be moved out of the build directory.
> # If it is, it will not operate correctly.
> # Sed substitution that helps us do robust quoting. It backslashifies
> # metacharacters that are still active within double-quoted strings.
> sed_quote_subst='s/\([`"$\\]\)/\\\1/g'
> # Be Bourne compatible
> if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
> emulate sh
> NULLCMD=:
> # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
> etc etc
> ls -ld /usr/lib/cgi-bin/ ----> drwxr-xr-x 2 root root 4096 Nov 8
> 23:37 /usr/lib/cgi-bin/
> ls -l /usr/lib/cgi-bin ----> total 0 (?? strange huh..)
> I have a feeling that there has been a mistake in copying... cp mapserv
> /var/www/cgi-bin/
> Does this mean that mapserv file is copied into /var/www and takes the
> name "cgi-bin"?? because the path on my system stops at /var/www/cgi-bin
> I'm using Linux mint 13 Maya
> *Απο:* Stephen Woodbridge <woodbri at swoodbridge.com>
> *Προς:* Stefanos Anastasiou <emperor_stef at yahoo.gr>; mapserver-users
> <mapserver-users at lists.osgeo.org>
> *Στάλθηκε:* 9:36 μ.μ. Δευτέρα, 4 Μαρτίου 2013
> *Θέμα:* Re: Σχετ: [mapserver-users] First attempt on Maserver
> Ok, my error.
> You should probably NOT have the file /var/www/cgi-bin this looks very
> bad. I would look at this file and see what it is doing.
> What you should have:
> $ ls -ld /usr/lib/cgi-bin/
> drwxr-xr-x 2 root root 4096 Mar 16 2012 /usr/lib/cgi-bin/
> $ ls -l /usr/lib/cgi-bin/
> total 36
> -rwxr-xr-x 1 root root 34461 Mar 28 2012 mapserv
> $ /usr/lib/cgi-bin/mapserv -v
> MapServer version 6.2.0 OUTPUT=PNG
> OUTPUT=JPEG SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV INPUT=JPEG
> INPUT=SHAPEFILE
> What Linux distribution are you running?
> -Steve
> On 3/4/2013 1:32 PM, Stefanos Anastasiou wrote:
> > OK I'm pasting the results of the commands:
> > file /var/www/cgi-bin ----> /var/www/cgi-bin: Bourne-Again shell
> > script, ASCII text executable, with very long lines
> > ls -l /var/www/cgi-bin ----> -rwxr-xr-x 1 root root 7542 Feb 28 20:42
> > /var/www/cgi-bin
> > /var/www/cgi-bin/mapserv -v ----> MapServer version 6.2.0 OUTPUT=PNG
> > INPUT=SHAPEFILE
> > What is strange though is that I installed apache through the
> > repositories and there is no config file, no log file... nothing... just
> > a folder /var/www
> > Apart from that server seems to work.. no need to restart every time...
> > what is strange though is that I get a weird message when I
> > start/restart/stop which is:
> > * Restarting web server apache2 apache2: Could not reliably
> > determine the server's fully qualified domain name, using 127.0.1.1 for
> > ServerName
> > ... waiting apache2: Could not reliably determine the server's fully
> > qualified domain name, using 127.0.1.1 for ServerName
> > what's wrong here?
> <mailto:woodbri at swoodbridge.com>>
> > *Προς:* mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> > *Στάλθηκε:* 10:06 μ.μ. Πέμπτη, 28 Φεβρουαρίου 2013
> > *Θέμα:* Re: [mapserver-users] First attempt on Maserver
> > On 2/28/2013 2:14 PM, Stefanos Anastasiou wrote:
> > > Hello everyone!
> > > I'm quite new to mapserver and I'm experimenting with the 2 first
> > > examples of Kropla's book... the first one, that is supposed to
> produce
> > > just an image... I click on "Click me" button and the message I
> get is:
> > > Not Found
> > > The requested URL /cgi-bin/mapserv was not found on this server
> > > I don't get it.. according to the instructions cp mapserv
> > /var/www/cgi-bin
> > > Why isn't it working?
> > OK, there are a bunch of assumptions in the above:
> > cp mapserv /var/www/cgi-bin
> > assumes the apache or your webserver is configured to look for cgi-bin
> > files in this directory
> > assumes that the directory already exists. what does these report:
> > ls -l /var/www/cgi-bin/mapserv
> > If the above looks ok, then you probably need to look at the apache
> > config. If you changed the apache config as part of your install, have
> > you restarted apache:
> > sudo /etc/init.d/apache2 restart
> > or
> > sudo /etc/init.d/apache restart
> > -Steve W
> > mapserver-users mailing list
> <mailto:mapserver-users at lists.osgeo.org>>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
