[mapserver-users] build mapserver 6.2 freetype error
Icadedt
icadedt at yahoo.fr
Wed Mar 13 02:35:20 PDT 2013
hi,
im trying to build mapserver 6.2:
i type this:
./configure --with-ogr=/usr/bin/gdal-config --with-gdal=/usr/bin/gdal-config
--with-httpd=/usr/sbin/httpd --with-wfsclient --with-wmsclient
--enable-debug --with-curl-config=/usr/bin/curl-config
--with-proj=/usr/local --with-tiff --with-gd=/usr/share/locale/
--with-jpeg --with-freetype=/usr/lib64/ --with-threads --with-wcs --with-postgis=/usr/local/database/bin/pg_config --with-libiconv=/usr
--with-geos=/usr/local/geos-3.3.5/tools/geos-config
--with-xml2-config=/usr/bin/xml2-config --with-sos
but i have this error about freetype:
checking if pkg-config path is provided... checking for pkg-config... /usr/bin/pkg-config
checking for freetype-config... no
checking for FT_Init_FreeType in -lfreetype... no
configure: error: unable to link - reconfigure with correct --with-freetype=dir
i checked freetype-2.3.11-14.el6_3.1.x86_64 is already installed
Thanks in advance
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130313/e121eeb6/attachment.html>
