[mapserver-users] How to integrate Openlayers + MapScript C# + Postgis
Fernando Norte
fernando at globalgeo.com.br
Fri Mar 15 05:32:04 PDT 2013
Olá Marco,
This link bellow helps me a lot to use the WMS MapServer feature.
http://augusttown.blogspot.com.br/2010/01/customize-wms-getfeatureinfo-response.html
You don't really need the C# or develop any program to bring basic
information, all you need is in the MapServer and openLayers.
Only if you need some dynamic requests I'll need the MapScript. I don't
know if there is any C# MapScript library like had to PHP and Python.
BTW there is another information that helps me to control better the layers
dynamically with the Run-time CGI in the MapServer.
http://mapserver.org/cgi/runsub.html
Keep in touch and good luck,
*Fernando Norte*
Desenvolvedor SIGWeb
tel.(31) 2533.9900
cel.(31) 9119.8814
skype: fernandoglobalgeo
Endereço: Alameda do Ingá, 88, 6º andar, Vale do Sereno
Nova Lima/MG - CEP: 34.000-000
www.globalgeo.com.br
"O presente documento pode conter material confidencial ou seu sigilo é
protegido por lei.
Quaisquer informações nele contida são destinadas exclusivamente ao(s)
seu(s) destinatário(s)
não devendo em nenhuma hipótese ser repassado a terceiros".
2013/3/14 Marco Araujo <marcoaraujolsys at hotmail.com>
> Hi everybody,
> I'm trying to develop an application (ASP.NET C#) that gets the database
> (postgis) map through conditions "where" and process adjustments by
> mapscript and provide the map to be viewed by openlayer.
> Can anyone guide me on how I should proceed?
> I need a WMS (mapserver) to display dynamic data (from database)?
> Already have the following:
> 1. up and running MapServer CGI in my Windows2008 (64bits) under IIS 7.5
> (not apache).
> 2. The database postgis mount but I have no idea how to retrieve the data
> and presents it in openlayers.
> 3. Tests (successfully) with openlayers presenting a static map of
> mapserver as follows:
> /layer = new OpenLayers.Layer.WMS("WorldMap",
> "http://localhost/MapServer/mapserv.exe?
> map=C:/maps/itasca.map&mode=map&template=openlayers&layer=lakespy2&layer=dlgstln2");/
> If you can help me I appreciate it.
> Sincerely,
> Marco Araujo
> Brazil / Sao Paulo
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130315/57434d6f/attachment.html>
