[mapserver-users] postgis layers don't show up
Pedro Costa
pedrocostaarma at sapo.pt
Wed Mar 13 07:50:01 PDT 2013
Ok, i got some information [1]....
I can see that mapserver tried get the layers....But no errors, i think...
[1] http://pastebin.com/fmnBLWcw
Em 13-03-2013 12:53, Yves Jacolin (Free) escreveu:
> Hello,
> Could you try to add:
> DEBUG 5
> in the LAYER object. You can find some useful information in the mapserver log
> and see the request sent by MapServer.
> Regards,
> Y.
> Le mercredi 13 mars 2013 12:26:31 Pedro Costa a écrit :
>> Hi,
>> Yes, sure...
>> No, nothing about the table....
>> Thanks
>> LAYER
>> NAME "ruas"
>> STATUS DEFAULT
>> TYPE LINE
>> CONNECTIONTYPE postgis
>> PROCESSING "CLOSE_CONNECTION=DEFER"
>> CONNECTION "user=pedro password=****** dbname=norte host=localhost
>> options='-c client_encoding=LATIN1'"
>> DATA "the_geom from ruas using unique n_rua using srid=27492"
>> TOLERANCE 3
>> TOLERANCEUNITS pixels
>> TEMPLATE void
>> PROJECTION
>> "init=epsg:27492"
>> END
>> METADATA
>> "DESCRIPTION" "Ruas"
>> "RESULT_FIELDS" "n_rua"
>> "RESULT_HEADERS" "ID"
>> "ows_title" "Ruas"
>> END # Metadata
>> CLASS
>> Name 'ruas'
>> COLOR 0 0 0
>> END # Class
>> END
>> Em 13-03-2013 12:21, Yves Jacolin (Free) escreveu:
>>> Hello,
>>> Could you post you layer object from your mapfile?
>>> Does the log says something about your postgis table?
>>> Thanks,
>>> Y.
>>> Le mercredi 13 mars 2013 11:40:29 Pedro Costa a écrit :
>>>> Hi guys,
>>>> I have one mapfile with conections to postgis layers and one raster.
>>>> My problem is that the layers from postgis don't show up...If i make the
>>>> request without the raster i got only white images...
>>>> I have the debug level in 5 and I got no erros in all logs (including
>>>> apache)...
>>>> The permissions of the database are correct because I tried accessing
>>>> with qgis and it worked fine. I'm also try specified the projection
>>>> ("using srid = 27493") but without sucess...
>>>> I'm also tried add one of the Iayers of db but from a shape and worked
>>>> fine...
>>>> Furthermore, very strange is that when I try to run mapfile with
>>>> pmapper, I can search for attributes and zoom to the correct areas
>>>> (despite can't see geometries) ...
>>>> Anybody have an idea?
>>>> Thanks
>>>> SO: Ubuntu server
>>>> MapServer version 6.0.1
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
