[mapserver-users] postgis layers don't show up
Yves Jacolin (Free)
yjacolin at free.fr
Wed Mar 13 08:20:25 PDT 2013
Hum, are you sure about your projection or the bbox requested?
MapServer send the request to Postgresql but get 0 record.
Y.
Le mercredi 13 mars 2013 14:50:01 Pedro Costa a écrit :
> Ok, i got some information [1]....
> I can see that mapserver tried get the layers....But no errors, i think...
> [1] http://pastebin.com/fmnBLWcw
> Em 13-03-2013 12:53, Yves Jacolin (Free) escreveu:
> > Hello,
> > Could you try to add:
> > DEBUG 5
> > in the LAYER object. You can find some useful information in the mapserver
> > log and see the request sent by MapServer.
> > Regards,
> > Y.
> > Le mercredi 13 mars 2013 12:26:31 Pedro Costa a écrit :
> >> Hi,
> >> Yes, sure...
> >> No, nothing about the table....
> >> Thanks
> >> LAYER
> >> NAME "ruas"
> >> STATUS DEFAULT
> >> TYPE LINE
> >> CONNECTIONTYPE postgis
> >> PROCESSING "CLOSE_CONNECTION=DEFER"
> >> CONNECTION "user=pedro password=****** dbname=norte host=localhost
> >> options='-c client_encoding=LATIN1'"
> >> DATA "the_geom from ruas using unique n_rua using srid=27492"
> >> TOLERANCE 3
> >> TOLERANCEUNITS pixels
> >> TEMPLATE void
> >> PROJECTION
> >> "init=epsg:27492"
> >> END
> >> METADATA
> >> "DESCRIPTION" "Ruas"
> >> "RESULT_FIELDS" "n_rua"
> >> "RESULT_HEADERS" "ID"
> >> "ows_title" "Ruas"
> >> END # Metadata
> >> CLASS
> >> Name 'ruas'
> >> COLOR 0 0 0
> >> END # Class
> >> END
> >> Em 13-03-2013 12:21, Yves Jacolin (Free) escreveu:
> >>> Hello,
> >>> Could you post you layer object from your mapfile?
> >>> Does the log says something about your postgis table?
> >>> Thanks,
> >>> Y.
> >>> Le mercredi 13 mars 2013 11:40:29 Pedro Costa a écrit :
> >>>> Hi guys,
> >>>> I have one mapfile with conections to postgis layers and one raster.
> >>>> My problem is that the layers from postgis don't show up...If i make
> >>>> the
> >>>> request without the raster i got only white images...
> >>>> I have the debug level in 5 and I got no erros in all logs (including
> >>>> apache)...
> >>>> The permissions of the database are correct because I tried accessing
> >>>> with qgis and it worked fine. I'm also try specified the projection
> >>>> ("using srid = 27493") but without sucess...
> >>>> I'm also tried add one of the Iayers of db but from a shape and worked
> >>>> fine...
> >>>> Furthermore, very strange is that when I try to run mapfile with
> >>>> pmapper, I can search for attributes and zoom to the correct areas
> >>>> (despite can't see geometries) ...
> >>>> Anybody have an idea?
> >>>> Thanks
> >>>> SO: Ubuntu server
> >>>> MapServer version 6.0.1
> >>>> _______________________________________________
> >>>> mapserver-users mailing list
> >>>> mapserver-users at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
