[mapserver-users] postgis layers don't show up
Pedro Costa
pedrocostaarma at sapo.pt
Wed Mar 13 10:12:14 PDT 2013
Thanks to all.
The problem is the query.despite don't give me any error returns 0
features...
This happens because the 'where with the polygon' [1]...
Anybody knows the origin of that polygon?
select encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex') as
geom,"n_rua"
from ruas
where the_geom && GeomFromText('POLYGON((88071.2044330519
122184.53,88071.2044330519 124022.08,91531.2955669481
124022.08,91531.2955669481 122184.53,88071.2044330519 122184.53))',27492)
Em 13-03-2013 16:54, Carlo Pelliconi escreveu:
> I think like others that the problem could be in srid definition.
> Remember that you need to define an srid for the mapfile and an srid
> for each layer in the mapfile.
> When using postgis connectiontype I also put "using
> srid=yourPostGisLayerSrid" in the DATA sql statement of the layer
> (mandatory? I don't know, but it works)
> Hope this helps.
> Best Regards, Carlo
> Il 13/03/2013 12:40, Pedro Costa ha scritto:
>> Hi guys,
>> I have one mapfile with conections to postgis layers and one raster.
>> My problem is that the layers from postgis don't show up...If i make
>> the request without the raster i got only white images...
>> I have the debug level in 5 and I got no erros in all logs (including
>> apache)...
>> The permissions of the database are correct because I tried accessing
>> with qgis and it worked fine. I'm also try specified the projection
>> ("using srid = 27493") but without sucess...
>> I'm also tried add one of the Iayers of db but from a shape and
>> worked fine...
>> Furthermore, very strange is that when I try to run mapfile with
>> pmapper, I can search for attributes and zoom to the correct areas
>> (despite can't see geometries) ...
>> Anybody have an idea?
>> Thanks
>> SO: Ubuntu server
>> MapServer version 6.0.1
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
