[mapserver-users] postgis layers don't show up
Pedro Costa
pedrocostaarma at sapo.pt
Wed Mar 13 10:49:21 PDT 2013
Em 13-03-2013 17:39, Stephen Woodbridge escreveu:
> So What do you get in pgadmin or psql with:
> select count(*)
> from ruas
> where the_geom && GeomFromText('POLYGON((88071.2044330519
> 122184.53,88071.2044330519 124022.08,91531.2955669481
> 124022.08,91531.2955669481 122184.53,88071.2044330519
> 122184.53))',27492);
nothing...count = 0...
> select st_astext(st_extents(st_collect(the_geom))) from ruas;
Previously i have compared the result of 'st_extent' with extent in
mapfile and its the same....
Your query with st_collects give me an error (ERROR: aggregate function
calls cannot be nested)....
> -Steve
> On 3/13/2013 1:22 PM, Pedro Costa wrote:
>> Yes, i confirmed that right now, its the bb but i don't understand the
>> problem because in other server (with the same coordinates) this works
>> fine.
>> i'm also confirmed the extent in qgis and its correct...
>> my mapfile top data:
>> EXTENT 88386.2 122329.41 91216.3 124022.08
>> UNITS meters
>> SIZE 500 500
>> SHAPEPATH "shape"
>> SYMBOLSET "../common/symbols/symbols-pmapper.sym"
>> FONTSET "../common/fonts/msfontset.txt"
>> RESOLUTION 96
>> IMAGETYPE png
>> INTERLACE OFF
>> PROJECTION
>> "init=epsg:27493"
>> END
>> my layer:
>> LAYER
>> NAME "ruas"
>> STATUS DEFAULT
>> DEBUG 5
>> TYPE LINE
>> CONNECTIONTYPE postgis
>> PROCESSING "CLOSE_CONNECTION=DEFERl"
>> CONNECTION "user=pedro password=****** dbname=norte host=localhost
>> options='-c client_encoding=LATIN1'"
>> DATA "the_geom from ruas using unique n_rua using srid=27493"
>> TOLERANCE 3
>> TOLERANCEUNITS pixels
>> TEMPLATE void
>> PROJECTION
>> "init=epsg:27493"
>> END
>> METADATA
>> "DESCRIPTION" "Ruas"
>> "RESULT_FIELDS" "id"
>> "RESULT_HEADERS" "id"
>> "ows_title" "Ruas "
>> END # Metadata
>> CLASS
>> Name 'ruas'
>> COLOR 0 0 0
>> END # Class
>> END
>> Em 13-03-2013 17:14, Stephen Woodbridge escreveu:
>>> The polygon is the bounding box of the image that you requested.
>>> Mapserver only needs the geometries the cross of the map image and
>>> this is what the where clause is doing.
>>> Why do you thin this is not correct? What does the top of you mapfile
>>> look like and what does this LAYER definition look like?
>>> -Steve W
>>> On 3/13/2013 1:12 PM, Pedro Costa wrote:
>>>> Thanks to all.
>>>> The problem is the query.despite don't give me any error returns 0
>>>> features...
>>>> This happens because the 'where with the polygon' [1]...
>>>> Anybody knows the origin of that polygon?
>>>> select encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex') as
>>>> geom,"n_rua"
>>>> from ruas
>>>> 122184.53))',27492)
>>>> Em 13-03-2013 16:54, Carlo Pelliconi escreveu:
>>>>> I think like others that the problem could be in srid definition.
>>>>> Remember that you need to define an srid for the mapfile and an srid
>>>>> for each layer in the mapfile.
>>>>> When using postgis connectiontype I also put "using
>>>>> srid=yourPostGisLayerSrid" in the DATA sql statement of the layer
>>>>> (mandatory? I don't know, but it works)
>>>>> Hope this helps.
>>>>> Best Regards, Carlo
>>>>> Il 13/03/2013 12:40, Pedro Costa ha scritto:
>>>>>> Hi guys,
>>>>>> I have one mapfile with conections to postgis layers and one raster.
>>>>>> My problem is that the layers from postgis don't show up...If i make
>>>>>> the request without the raster i got only white images...
>>>>>> I have the debug level in 5 and I got no erros in all logs
>>>>>> (including
>>>>>> apache)...
>>>>>> The permissions of the database are correct because I tried
>>>>>> accessing
>>>>>> with qgis and it worked fine. I'm also try specified the projection
>>>>>> ("using srid = 27493") but without sucess...
>>>>>> I'm also tried add one of the Iayers of db but from a shape and
>>>>>> worked fine...
>>>>>> Furthermore, very strange is that when I try to run mapfile with
>>>>>> pmapper, I can search for attributes and zoom to the correct areas
>>>>>> (despite can't see geometries) ...
>>>>>> Anybody have an idea?
>>>>>> Thanks
>>>>>> SO: Ubuntu server
>>>>>> MapServer version 6.0.1
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
