[mapserver-users] postgis layers don't show up
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Mar 14 06:13:45 PDT 2013
You can not do a simple dump and restore. When you upgrade a database
with postgis data there is an upgrade procedure that you have to go
through.
google: postgis upgrade 1.5 to 2.0
Lots of help there.
-Steve W
On 3/14/2013 8:44 AM, Pedro Costa wrote:
> I found the problem...
> I don't know why but the problem is bucause i make a dump from database
> with postgis 1.5 and in new databse i have the postgis 2...
> so the problem its the dump and restore....
> If i make the same query in database with postgis 1.5 i got some
> records....
> Em 14-03-2013 09:56, Pedro Costa escreveu:
>> Very strange...I got nothing again:
>> select st_astext(st_extent(the_geom)) from ruas:
>> RESULT:
>> "POLYGON((88386.2413216648 122184.527972102,88386.2413216648
>> 124022.075913784,91216.2575858403 124022.075913784,91216.2575858403
>> 122184.527972102,88386.2413216648 122184.527972102))"
>> select count(*)
>> from ruas
>> where the_geom && GeomFromText
>> ('POLYGON((88386.2413216648 122184.527972102,88386.2413216648
>> 122184.527972102,88386.2413216648 122184.527972102))',27492);
>> RESULT: 0
>> Em 13-03-2013 18:27, Stephen Woodbridge escreveu:
>>> On 3/13/2013 1:49 PM, Pedro Costa wrote:
>>>> Em 13-03-2013 17:39, Stephen Woodbridge escreveu:
>>>>> So What do you get in pgadmin or psql with:
>>>>> select count(*)
>>>>> from ruas
>>>>> where the_geom && GeomFromText('POLYGON((88071.2044330519
>>>>> 122184.53,88071.2044330519 124022.08,91531.2955669481
>>>>> 124022.08,91531.2955669481 122184.53,88071.2044330519
>>>>> 122184.53))',27492);
>>>> nothing...count = 0...
>>> This means there is some kind of disconnect between the data in the
>>> database and how you have it defined in the mapfile.
>>>>> select st_astext(st_extents(st_collect(the_geom))) from ruas;
>>>> Previously i have compared the result of 'st_extent' with extent in
>>>> mapfile and its the same....
>>>> Your query with st_collects give me an error (ERROR: aggregate function
>>>> calls cannot be nested)....
>>> Try:
>>> select st_astext(st_extents(the_geom)) from ruas;
>>> Once you get this you will have the min and max extents of the data
>>> in the database and you can compare that to the polygon above and see
>>> if it overlaps.
>>> -Steve
>>>>> -Steve
>>>>> On 3/13/2013 1:22 PM, Pedro Costa wrote:
>>>>>> Yes, i confirmed that right now, its the bb but i don't understand
>>>>>> the
>>>>>> problem because in other server (with the same coordinates) this
>>>>>> works
>>>>>> fine.
>>>>>> i'm also confirmed the extent in qgis and its correct...
>>>>>> my mapfile top data:
>>>>>> EXTENT 88386.2 122329.41 91216.3 124022.08
>>>>>> UNITS meters
>>>>>> SIZE 500 500
>>>>>> SHAPEPATH "shape"
>>>>>> SYMBOLSET "../common/symbols/symbols-pmapper.sym"
>>>>>> FONTSET "../common/fonts/msfontset.txt"
>>>>>> RESOLUTION 96
>>>>>> IMAGETYPE png
>>>>>> INTERLACE OFF
>>>>>> PROJECTION
>>>>>> "init=epsg:27493"
>>>>>> END
>>>>>> my layer:
>>>>>> LAYER
>>>>>> NAME "ruas"
>>>>>> STATUS DEFAULT
>>>>>> DEBUG 5
>>>>>> TYPE LINE
>>>>>> CONNECTIONTYPE postgis
>>>>>> PROCESSING "CLOSE_CONNECTION=DEFERl"
>>>>>> CONNECTION "user=pedro password=****** dbname=norte
>>>>>> host=localhost
>>>>>> options='-c client_encoding=LATIN1'"
>>>>>> DATA "the_geom from ruas using unique n_rua using srid=27493"
>>>>>> TOLERANCE 3
>>>>>> TOLERANCEUNITS pixels
>>>>>> TEMPLATE void
>>>>>> PROJECTION
>>>>>> "init=epsg:27493"
>>>>>> END
>>>>>> METADATA
>>>>>> "DESCRIPTION" "Ruas"
>>>>>> "RESULT_FIELDS" "id"
>>>>>> "RESULT_HEADERS" "id"
>>>>>> "ows_title" "Ruas "
>>>>>> END # Metadata
>>>>>> CLASS
>>>>>> Name 'ruas'
>>>>>> COLOR 0 0 0
>>>>>> END # Class
>>>>>> END
>>>>>> Em 13-03-2013 17:14, Stephen Woodbridge escreveu:
>>>>>>> The polygon is the bounding box of the image that you requested.
>>>>>>> Mapserver only needs the geometries the cross of the map image and
>>>>>>> this is what the where clause is doing.
>>>>>>> Why do you thin this is not correct? What does the top of you
>>>>>>> mapfile
>>>>>>> look like and what does this LAYER definition look like?
>>>>>>> -Steve W
>>>>>>> On 3/13/2013 1:12 PM, Pedro Costa wrote:
>>>>>>>> Thanks to all.
>>>>>>>> The problem is the query.despite don't give me any error returns 0
>>>>>>>> features...
>>>>>>>> This happens because the 'where with the polygon' [1]...
>>>>>>>> Anybody knows the origin of that polygon?
>>>>>>>> select encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex') as
>>>>>>>> geom,"n_rua"
>>>>>>>> from ruas
>>>>>>>> 122184.53))',27492)
>>>>>>>> Em 13-03-2013 16:54, Carlo Pelliconi escreveu:
>>>>>>>>> I think like others that the problem could be in srid definition.
>>>>>>>>> Remember that you need to define an srid for the mapfile and an
>>>>>>>>> srid
>>>>>>>>> for each layer in the mapfile.
>>>>>>>>> When using postgis connectiontype I also put "using
>>>>>>>>> srid=yourPostGisLayerSrid" in the DATA sql statement of the layer
>>>>>>>>> (mandatory? I don't know, but it works)
>>>>>>>>> Hope this helps.
>>>>>>>>> Best Regards, Carlo
>>>>>>>>> Il 13/03/2013 12:40, Pedro Costa ha scritto:
>>>>>>>>>> Hi guys,
>>>>>>>>>> I have one mapfile with conections to postgis layers and one
>>>>>>>>>> raster.
>>>>>>>>>> My problem is that the layers from postgis don't show up...If
>>>>>>>>>> i make
>>>>>>>>>> the request without the raster i got only white images...
>>>>>>>>>> I have the debug level in 5 and I got no erros in all logs
>>>>>>>>>> (including
>>>>>>>>>> apache)...
>>>>>>>>>> The permissions of the database are correct because I tried
>>>>>>>>>> accessing
>>>>>>>>>> with qgis and it worked fine. I'm also try specified the
>>>>>>>>>> projection
>>>>>>>>>> ("using srid = 27493") but without sucess...
>>>>>>>>>> I'm also tried add one of the Iayers of db but from a shape and
>>>>>>>>>> worked fine...
>>>>>>>>>> Furthermore, very strange is that when I try to run mapfile with
>>>>>>>>>> pmapper, I can search for attributes and zoom to the correct
>>>>>>>>>> areas
>>>>>>>>>> (despite can't see geometries) ...
>>>>>>>>>> Anybody have an idea?
>>>>>>>>>> Thanks
>>>>>>>>>> SO: Ubuntu server
>>>>>>>>>> MapServer version 6.0.1
>>>>>>>>>> _______________________________________________
>>>>>>>>>> mapserver-users mailing list
>>>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
