[mapserver-users] postgis layers don't show up
Worth Lutz
wal3 at mindspring.com
Thu Mar 14 06:24:18 PDT 2013
Here is Paul Ramsey's solution for that type of problem:
http://blog.cleverelephant.ca/2010/09/postgis-back-up-restore.html
Worth Lutz
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Pedro Costa
Sent: Thursday, March 14, 2013 8:44 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] postgis layers don't show up
I found the problem...
I don't know why but the problem is bucause i make a dump from database
with postgis 1.5 and in new databse i have the postgis 2...
so the problem its the dump and restore....
If i make the same query in database with postgis 1.5 i got some records....
Em 14-03-2013 09:56, Pedro Costa escreveu:
> Very strange...I got nothing again:
> select st_astext(st_extent(the_geom)) from ruas:
> RESULT:
> "POLYGON((88386.2413216648 122184.527972102,88386.2413216648
> 124022.075913784,91216.2575858403 124022.075913784,91216.2575858403
> 122184.527972102,88386.2413216648 122184.527972102))"
> select count(*)
> from ruas
> where the_geom && GeomFromText
> ('POLYGON((88386.2413216648 122184.527972102,88386.2413216648
> 122184.527972102,88386.2413216648 122184.527972102))',27492);
> RESULT: 0
> Em 13-03-2013 18:27, Stephen Woodbridge escreveu:
>> On 3/13/2013 1:49 PM, Pedro Costa wrote:
>>> Em 13-03-2013 17:39, Stephen Woodbridge escreveu:
>>>> So What do you get in pgadmin or psql with:
>>>> select count(*)
>>>> from ruas
>>>> where the_geom && GeomFromText('POLYGON((88071.2044330519
>>>> 122184.53,88071.2044330519 124022.08,91531.2955669481
>>>> 124022.08,91531.2955669481 122184.53,88071.2044330519
>>>> 122184.53))',27492);
>>> nothing...count = 0...
>> This means there is some kind of disconnect between the data in the
>> database and how you have it defined in the mapfile.
>>>> select st_astext(st_extents(st_collect(the_geom))) from ruas;
>>> Previously i have compared the result of 'st_extent' with extent in
>>> mapfile and its the same....
>>> Your query with st_collects give me an error (ERROR: aggregate function
>>> calls cannot be nested)....
>> Try:
>> select st_astext(st_extents(the_geom)) from ruas;
>> Once you get this you will have the min and max extents of the data
>> in the database and you can compare that to the polygon above and see
>> if it overlaps.
>> -Steve
>>>> -Steve
>>>> On 3/13/2013 1:22 PM, Pedro Costa wrote:
>>>>> Yes, i confirmed that right now, its the bb but i don't understand
>>>>> the
>>>>> problem because in other server (with the same coordinates) this
>>>>> works
>>>>> fine.
>>>>> i'm also confirmed the extent in qgis and its correct...
>>>>> my mapfile top data:
>>>>> EXTENT 88386.2 122329.41 91216.3 124022.08
>>>>> UNITS meters
>>>>> SIZE 500 500
>>>>> SHAPEPATH "shape"
>>>>> SYMBOLSET "../common/symbols/symbols-pmapper.sym"
>>>>> FONTSET "../common/fonts/msfontset.txt"
>>>>> RESOLUTION 96
>>>>> IMAGETYPE png
>>>>> INTERLACE OFF
>>>>> PROJECTION
>>>>> "init=epsg:27493"
>>>>> END
>>>>> my layer:
>>>>> LAYER
>>>>> NAME "ruas"
>>>>> STATUS DEFAULT
>>>>> DEBUG 5
>>>>> TYPE LINE
>>>>> CONNECTIONTYPE postgis
>>>>> PROCESSING "CLOSE_CONNECTION=DEFERl"
>>>>> CONNECTION "user=pedro password=****** dbname=norte
>>>>> host=localhost
>>>>> options='-c client_encoding=LATIN1'"
>>>>> DATA "the_geom from ruas using unique n_rua using srid=27493"
>>>>> TOLERANCE 3
>>>>> TOLERANCEUNITS pixels
>>>>> TEMPLATE void
>>>>> PROJECTION
>>>>> "init=epsg:27493"
>>>>> END
>>>>> METADATA
>>>>> "DESCRIPTION" "Ruas"
>>>>> "RESULT_FIELDS" "id"
>>>>> "RESULT_HEADERS" "id"
>>>>> "ows_title" "Ruas "
>>>>> END # Metadata
>>>>> CLASS
>>>>> Name 'ruas'
>>>>> COLOR 0 0 0
>>>>> END # Class
>>>>> END
>>>>> Em 13-03-2013 17:14, Stephen Woodbridge escreveu:
>>>>>> The polygon is the bounding box of the image that you requested.
>>>>>> Mapserver only needs the geometries the cross of the map image and
>>>>>> this is what the where clause is doing.
>>>>>> Why do you thin this is not correct? What does the top of you
>>>>>> mapfile
>>>>>> look like and what does this LAYER definition look like?
>>>>>> -Steve W
>>>>>> On 3/13/2013 1:12 PM, Pedro Costa wrote:
>>>>>>> Thanks to all.
>>>>>>> The problem is the query.despite don't give me any error returns 0
>>>>>>> features...
>>>>>>> This happens because the 'where with the polygon' [1]...
>>>>>>> Anybody knows the origin of that polygon?
>>>>>>> select encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex') as
>>>>>>> geom,"n_rua"
>>>>>>> from ruas
>>>>>>> 122184.53))',27492)
>>>>>>> Em 13-03-2013 16:54, Carlo Pelliconi escreveu:
>>>>>>>> I think like others that the problem could be in srid definition.
>>>>>>>> Remember that you need to define an srid for the mapfile and an
>>>>>>>> srid
>>>>>>>> for each layer in the mapfile.
>>>>>>>> When using postgis connectiontype I also put "using
>>>>>>>> srid=yourPostGisLayerSrid" in the DATA sql statement of the layer
>>>>>>>> (mandatory? I don't know, but it works)
>>>>>>>> Hope this helps.
>>>>>>>> Best Regards, Carlo
>>>>>>>> Il 13/03/2013 12:40, Pedro Costa ha scritto:
>>>>>>>>> Hi guys,
>>>>>>>>> I have one mapfile with conections to postgis layers and one
>>>>>>>>> raster.
>>>>>>>>> My problem is that the layers from postgis don't show up...If
>>>>>>>>> i make
>>>>>>>>> the request without the raster i got only white images...
>>>>>>>>> I have the debug level in 5 and I got no erros in all logs
>>>>>>>>> (including
>>>>>>>>> apache)...
>>>>>>>>> The permissions of the database are correct because I tried
>>>>>>>>> accessing
>>>>>>>>> with qgis and it worked fine. I'm also try specified the
>>>>>>>>> projection
>>>>>>>>> ("using srid = 27493") but without sucess...
>>>>>>>>> I'm also tried add one of the Iayers of db but from a shape and
>>>>>>>>> worked fine...
>>>>>>>>> Furthermore, very strange is that when I try to run mapfile with
>>>>>>>>> pmapper, I can search for attributes and zoom to the correct
>>>>>>>>> areas
>>>>>>>>> (despite can't see geometries) ...
>>>>>>>>> Anybody have an idea?
>>>>>>>>> Thanks
>>>>>>>>> SO: Ubuntu server
>>>>>>>>> MapServer version 6.0.1
>>>>>>>>> _______________________________________________
>>>>>>>>> mapserver-users mailing list
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.2904 / Virus Database: 2641/6169 - Release Date: 03/13/13
